Hid?
Hid?
hey my driver side HID keeps tunring off when im driving but when i turn the lights on and off it turns back on I was just wondering does that seem like a problem with the buld or do i have another problem?
GS300 06
GS300 06
Could just be the bulb but that happened to me and it was the light assembly itself and you don't want it to be that.
The same exact thing was happening to me. What I did was swap the bulb from one side to the other. Its weird but I haven't had a problem since! Might want to try that. Doesn't hurt to give it a shot!
alright sounds good ill give it a try.....
whats a good brand of bulb that you would recommend for replacment.... or should i just stick with factory?.....
If you want the regular 4300k Phillips then eBay has the best prices. Just make sure you get new ones and not used.
Turbo, HID is using gas instead of filament. And when it get aged due to use it require more power to stay ON. When it get beyond the power the HID can put out, it'll turn off.
It turn on for the first few minutes because that is the starting stage, HID use more power when it starts and than switch to NORMAL mode... that's when the power is not enough for the gas to stay lighted.
