Wheel fitment question.
Sunk? They're fairly agressive I don't think they'll have the concave look at all. Are you going for an agressive or conservative look? Plan on doing fender mods.
I'm running 20X8.5 et 38 and 20X10 et 45. Typical offset for 3Gen GS's. Braver soles can work with more agressive settings.
Calf Implant Beta Tester
Hmm I'm running these wheels on a TL with 5mm spacers in the rear. Figured the 3GS could run more aggressive offsets!
Not sure. Planning on air but we'll see. Gotta buy a GS first
Still, I would think you would need to do more though, like ryan said, a little fender work and I think you would be ok.
3gs doesn't allow you to go very aggressive without modification. there are 2 3gs that i know of that are running aggressive offsets (i think around +11, but maybe single digit) but they both required a ton of work. my camber is not too bad. got 30k out of my last set of tires, at the same height that i am now. i think a 10mm spacer will bring your fronts out to where you probably want them.
And don't worry about it... if/when I get a GS, it won't be stock.
