Vias? or iSimple?
Question about this Vaistech thing:
Can I control the music through the steering wheel AND the touchscreen on the 2006 GS300?
Is it simple to browse through folders? Let's say I have a USB stick with 32 GB of music, which contains 200 folders. Is it pretty easy to navigate through this stuff?
Does anybody have a screenshot of what's on the touchscreen display on a 2006 GS 300 with this product?
exclusive matchup
yes you can control through touch screen and steering, but on the 06 it's gen4 nav, so things are not as intuitive. on gen5 you can have extended browsing including browsing by albums, playlists, genre, artists, etc... on gen4 it's just playlists.
you can read through the vml manual to get a better understanding on how the files need to be structured in order to play. there are some other posts as well members posting about vml, where if you don't have any playlist, then it will play everything one by one. if there is playlist, then only songs on playlist will be played, etc...
here's a screen shot of what it looks like on cd emulation
Group buy going on now in our vendor marketplace direct from Vaistech
https://www.clublexus.com/forums/clu...echnology.html
I plan on putting all my music on a USB if I buy this thing...
I'm pretty much going to have folders with the artist name, and then subfolders within that folder with that artist's albums.
So I'll have a folder titled EMINEM, then inside of that I'll have folders for each of his albums.
Is that something that's easy to browse through?
The USB will have about 25 main folders, and each of those folders will contain between 3 and 15 sub-folders.
The next question is...will it give me options for "shuffle folder" and "shuffle all" ?
Meaning, can I put ask the VAIS to shuffle the songs just in the folder I decide to play? Can I ask the VAIS to shuffle all the songs on the USB?
Club Lexus Vendor
Unfortunately VML won't support subfolders. So you will have to list every folder separately. You can have 99 folders for CD/MD changer emulation and 999 folders for CD-MP3 emulation. Number of songs can go up to 9999. And you can have upto 4 partitions on your USB source, primarily used with HDD connected to VML, internally or externally.
As far as shuffle you can only shuffle songs within a single folder. What I have seen people do to get shuffle all, is that they dump all songs into one folder and then put on shuffle.
Please let us know if you guys have anymore questions.
^ No subfolders? Not a huge problem.
So I can have up to 999 folders on a USB? That'll work.
What's do you mean by CD/MD emulation and CD-MP3 emulation?
The CD part is confusing me...I plan on using a USB stick(s).
How is the sound quality? Same as a CD?
exclusive matchup
on my sl2i-up, i honestly don't hear much difference in sound quality compared to cd
I do have a few questions for the VML… (not sure if you are the same person who answered my questions from the Vaistech website…but oh well)
You can PM me for the answers or reply here...
1. Partition: on the VML manual page 3 “Partitioned USB memory is compatible with this unit. (Can not be managed by Windows XP and Windows Vista).“, what does it mean?? If I were going to make partitions to my 16GB USB stick, will it work? Any recommended software?
2. Folder +50/-50: on the VML manual “Press and hold the RPT button to activate/disactivate playlist +50 mode.“ << It is a typo, for my 07 GS350, I have to press and hold SCAN to activate the +/-50 mode, RPT button does not do anything.
3. Category (Playlist, Artist, Album) Selection: what does this feature do?? Can you explain? Every time I try to perform this feature the only thing showing on the screen is Category: Playlist. The current music still plays and nothing to choose.
4. ipod interface: I found the only way to successfully utilize ipod is to make as many playlists like you would to a USB stick. This takes too much time to do in itune (one playlist at a time) versus you can drag and drop hundreds folders at one time to the USB stick. Is this true? Am I doing something wrong here?
Club Lexus Vendor
2. It is a type. DISC SCAN needs to be activated in order to access FOLDER +50 Folder -50. Good catch, we will fix it.
3. This has been mainly created for iPod, but can also be used for mass storage devices which have M3U playlists created.
4. Unless you have a 5th Gen navigation system in your Lexus you do have to have playlists set up in order to browse iPod.
Thanks!
I forgot to ask...how long does it take for this thing to read a USB?
Let's say the USB stick has 16 GB of data...how quickly does it load?
And how quick does it browse through 99 folders? Any loading times doing that?
Club Lexus Vendor
The way our system works is as soon as you inserted the flash drive or HDD into VML it will start loading data immediately and will save it in the cache folder (created automatically by VML). It will give you ability to browse your data as soon as it becomes available. For example it loaded 100 songs out of 1000 you have, so it will let you browse through your 100 while other 900 are loading. Also once your cache folder is built, next time you start the car or plug this flash drive in, there is no more loading, VML will take all information from cache, so all files are available immediately.
