Winshield washer system
08-01-10, 08:13 PM
Mine doesn`t work!
It doesn`t squirt not even a single drop of water.
What could it be? What to check? Anyone with experience?
08-01-10, 08:59 PM
Did you try it while your headlights were "ON"? I believe they only work when they're on.
08-01-10, 09:54 PM
exclusive matchup
you don't need headlights on for the windshield wipers to come on. the headlight washers yes. if it doesn't work maybe should get dealer to check on it
08-02-10, 12:06 AM
Sorry...read this wrong...thought you were talking about the Headlight washer.
08-02-10, 03:27 PM
Are your jets plugged up or the pump isn't working? can you hear any humming noise from the pump when you engage the switch?
08-08-10, 06:53 PM
Quote:
Originally Posted by
rominl
What happens if you activate the headlight washer with the headlights off?
08-08-10, 06:59 PM
arnieosp
I believe not.
That means the motor pump is gone or something might be loose/disconected?
I`ll have it check by an automotive electrician I know.
08-08-10, 07:14 PM
i never used mine for some reason,,,
08-08-10, 09:19 PM
exclusive matchup
LB23
don't think anything happens, but then i have never tried
08-09-10, 06:18 AM
rominl
Nothing happens. Kind of silly to put that limitation on it.
08-09-10, 06:29 AM
LB23
well what are you trying to clean, your windshield or your headlights?
08-09-10, 08:36 AM
well, maybe the windshield washer line got bent around your hood, that happend to me and the dealer replaced the line good as new.
k20trick
IS F (2008-2014)
12-07-15 10:08 AM
Joeb427
01-14-15 07:11 PM
praetor
04-25-14 06:35 AM
vuiskool
10-19-09 08:09 AM
fud
01-10-08 08:57 AM
