Help with some TSB's
Hi everyone I own a 2008 GS350 RWD and I need some help proving to the stealership that I have some common problems with my car. 1st off my brakes squeak and produce high amounts of brake dust. (SB0015-09R1 APR 09 Brakes - Front Brake Squeal/Squeak In Cold Weather) (SB0155-09 NOV 09 Brakes - Excessive Brake Dust On Front Wheels) And 2nd, I have a funky brand new tire smell coming from my A/C for about 30 seconds after I turn it on. (SB0011-09 FEB 09 A/C - Intermittent Unpleasant Odors)
The stealership told me that all of those issues are normal so I've been searching around and found TSBs on those problems. If someone has them on PDF, I would be forever grateful! I just need something to present to the dealership to show proof that I need this fixed! Thanks!
masterchri, have you been able to get your front brakes fixed? What is the actual TSIB#? My 08 GS350 AWD has a lot of brake dust and squeaking pretty bad. Where did you find these two TSIB? (SB0015-09R1 APR 09 Brakes - Front Brake Squeal/Squeak In Cold Weather) (SB0155-09 NOV 09 Brakes - Excessive Brake Dust On Front Wheels)
