Easy way to upgrade the ML amp and sub?
Old 10-20-10, 11:50 AM
GSLEX0586
GSLEX0586's Avatar
Default Easy way to upgrade the ML amp and sub?
so 1 of my good friends is a stereo-installer and did all the work on my cars but he's been hard to get ahold of lately.
Anywho, i want to upgrade the amp and subwoofer on my ML-equipped GS...
im wondering if this is a simple plug-n-play swap-out option? I don't plan to touch any of the speakers, just those 2 components. If so, what channel amp do i need? as for the subwoofer, im going to go with a "mild" 10" subwoofer...kicker, alpine, JL, etc...
i've worked on all my cars and have no problem swapping out radios, just never touched an amp or sub setup
Old 10-20-10, 03:29 PM
johnnunez2
johnnunez2's Avatar
what channel amp??? you mean how many channels. if its for one sub you can use either a mono block amp(one channel) or a 2- channel amp (bridged). just make sure you get your ohms right. thats a bit more complicated. depending on if you already have the sub. about the ml package thing. i wish i knew. i have a gs without the ml and i want to add a sub but am stumped as to how im going to do this.
Old 10-20-10, 06:02 PM
swtjlsy
swtjlsy's Avatar
A hi/low converter or a Jl Audio cleansweep will do the job either way it can be done teh easiest with a hi/low converter if you jsut want to add a sub.
Old 10-20-10, 06:06 PM
passnu2
passnu2's Avatar
please check the FAQ section
https://www.clublexus.com/forums/gs-...56k-no-no.html
Old 10-20-10, 07:07 PM
swtjlsy
swtjlsy's Avatar
Default Home made
decide to make my own boxes for less than half the cost will be finished then start a build thread when the car is done after paint. Made these for a Jl audio 13w3v2 1.62 cubic ft of air space.
Attached Thumbnails Easy way to upgrade the ML amp and sub?-img_0488.jpg   Easy way to upgrade the ML amp and sub?-img_0490.jpg   Easy way to upgrade the ML amp and sub?-img_0500.jpg   Easy way to upgrade the ML amp and sub?-img_0537.jpg   Easy way to upgrade the ML amp and sub?-img_0539.jpg
Old 10-20-10, 07:09 PM
swtjlsy
swtjlsy's Avatar
If anyone would like a fiberglass box for there Gs I would be happy to make them on to their spec for whatever sub they want to use just putting it out there that all.I enjoy making them.
Old 10-20-10, 07:17 PM
MrMark
MrMark's Avatar
Why not keep your ML unit and integrate an MS-8 into your system. Very simple to install and great flexibility.
Install is so simple....plug and play with the ML system. There's a lot of flexibility and the unit includes a remote with built in controls and 31 band EQ.
We mounted the unit in the trunk:
And I built a custom CF pod for the remote in my existing ash tray:
System sounds 100% better than using line converters and rats nest connections.
Old 10-20-10, 07:24 PM
Lex Luga
Lex Luga's Avatar
has nothing to do with the topic but u got a pic of ur car...i always like the BBS LM's and wondered how it would look like on a GS...talking about gslex0586
Old 10-20-10, 07:31 PM
swtjlsy
swtjlsy's Avatar
Well Mr Mark that piece from JBL is over $800 and why it is a nice piece it the size of a amp which mean more room. I do understand that you have to have something beside a hi/low and after I spent 500 for all of my cleansweep I can see why we must have something like this in our cars. So if you are not really replacing you head unit you still are in equipment.
swtjlsy
swtjlsy's Avatar
By the way since trunk set up
Old 10-21-10, 11:20 AM
johnnunez2
johnnunez2's Avatar
so whats the best way to add an amp and sub to a non ml stock nav.?
Old 10-21-10, 11:21 AM
johnnunez2
johnnunez2's Avatar
i read about that hi/low thing but it just looks weird to me. never seen that before.
Old 10-26-10, 02:44 AM
mr3gs300
mr3gs300's Avatar
hi-lo converter is the easiest way the speaker wires from the sub connect to the hi-lo converter then you use the rca plugs on the other end to connect to the new amp
Old 10-26-10, 04:44 AM
johnnunez2
johnnunez2's Avatar
where can i get a good hi low converter? i have a powerful amp and dnt want to hear any distortion.
Old 10-26-10, 07:40 AM
jre002
jre002's Avatar
Guys, I think the OP wanted to know about a direct swap of the ML amp and sub for better sound.
Quick Reply: Easy way to upgrade the ML amp and sub?
