ok, i add for second time coolant, and i will keep watching what is going on, if problem repeats, i will chack whater pump, till now i didnt find any leaks, thank you for fast answer
I wouldnt risk it! Go take it to a workshop and have them check out the cooling system. Because if the car over heats you can easily destroy a head gasket.
I was doing work on the bottom of the car and saw dried coolant. Mine is the 460 so yours might look a little different, but the coolant will look the same.
Dried coolant I saw when doing my sway bar bushings. This is looking up from the bottom of the car, near the oil filter area. This is dried coolant under the water pump, I had to reach up with the phone. Fresh coolant i saw later that made me decide to get the car fixed asap.
