RECALL: 2006 GS300 potential brake fluid leak
#47
My car is booked for this recall for December 4. Probably could have brought it in earlier, but that was the first Saturday they had available so I could get it done while I waited. So, at least in Canada, the dealerships seem ready for this now if you guys wanted to go ahead and check with your dealers.
My brake performance is actually kind of spongy compared to the last ES loaner I got, so I'm kind of wondering if my car is suffering from this or not. Could just be air in the system since I have not had the fluid flushed since I bought the car... time for the service is about 2 hours. I'm fairly sure that a brake system bleed needs to be done as part of this so hopefully one way or another the braking performance will improve.
#49
#51
the recall is to fix some seal on the brake master cylinder that can potentially leak...so if you still have the stock brake master cylinder, i would think this recall still applies to you (provided you are within the affected VIN range).
#52
BBK is totally unrelated to the master cylinder which is the piece in the engine compartment directly connected underneath the brake fluid reservoir. The master cylinder is what actually pressurizes the fluid to cause the calipers to engage.
#54
#59
Here: you have to create a free account profile, its awesome because you can view all your previous service records too off your vin#.
https://secure.drivers.lexus.com/lexusdrivers/home
#60
Someone knows where can I buy online this toyota genuine brake fluid?
Just for curiosity, and to be able to buy other genuine fluids.
