Bizarre electrical problem - car stuck
My car is having a bizarre electrical problem.
I pulled my car out of the parking spot. Parked it for 10-15 minutes max while I applied leather conditioner to the seats. Attempted to restart the car and it won't start. I don't get any of the low battery signals - its more like the car is dead. Nothing happens. The voltage indicator suggests it still has 12V. The battery should have a strong charge since it has been driven a lot over the past week.
The car is stuck, obstructing the space next to mine.
What should I do? Is there a way to put the car into neutral when the shifter won't even move?
As far as putting it in neutral I think you can insert the key (that pulls out of the fob) and pop the little black slotted thing next to the shifter up and then insert the key and you should be able to shift the car. It will explain this technque in the manual in more depth. Once you get it moved I would disconnect the battery for a little while then reconnect, kind of like rebooting your computer. After that, I don't know on these cars.
I got AAA out and they were able to start the car by connecting up a backup battery. Drove it around then parked it again.
After I parked and locked it and walked away something bizarre happened. As I was switching off the car, the HID fogs started flashing at high speed almost like strobe lights, and then all the lights switched off as the courtesy light timer completed its cycle. I wonder if there is a fault with the HID fog circuit causing the problems.
Really weird, especially being Halloween. I'm leaving on a business trip for 10 days in the morning. Hope the car works when I get back. Then I will drop it off at the dealer for extensive testing and also get the valve spring recall done while its there.
Also FYI the battery in the car is only 2 weeks old.
I parked the car. Switched off. All lights off, etc. Hour later got a low battery alert that it dropped below 11.5V.
Any thoughts? Could HID fogs malfunctioning cause this? I would have thought fogs cannot drain battery unless they are on.
that's what i was thinking.
your car is possessed.
maybe you messed something up when you installed your new battery. maybe something is shorting out. i dunno.
you CAN shift to neutral when your car won't start.
just turn the car on (press power button 2x, all dashboard lights on), without stepping on the brake.
then the shifter will unlock and you can shift to N and push your car so that you can jumpstart it with your other car.
up in the engine bay? if so, id try removing it from the bay and brining it down into the bumper itself. depending on what kit you have, ive seen a lot of people posting in the 2IS forum saying their ballast were causing a lot of problems went in the engine bay. mainly the frequencies coming off the ballast to other electrical components in the bay.
Good thing is I've never heard of HID ballasts from xenondepot causing any problems for anybody. I feel triple safe in that I not only bought from xenondepot, but I also ponied up and got the more expensive of their two kits and installed it down in my bumper away from all of the other electronic jazz.
