Couple of questions
Anybody knows if you can buy only the up/down motor of the sideview mirror?
Someone knows if you can use the rear multiplex network door ECU of the left rear window temporarily on the right rear window?
The right rear window is not reseting properly, so its flashing, I only need to reset it. So instead of buying a new ECU, can I switch them to reset that window and then take it back ?
And I cannot find anywhere the part number of that rear multiplex network door ECU RH, if I were to buy it anyway.
See picture attached. Thanks fellas.
I already know that page.
