How to reset oil maintenance warning?
Just changed the oil on my 2006 430, how do I reset the warning message on the dash? I don't have an owners manual so any help is appreciated.
Thanks in advance
Thanks in advance
This may work for the 430 but not sure
Are you getting the OIL MAINT RESET message? If so, here's how to get rid of it:
Push the “ODO TRIP” button in the switch box to change the display to current mileage (neither Trip A nor Trip B).
Turn the engine off.
Push engine-on button once (with foot off the gas pedal) to go to ACC mode. Press and hold “RESET” and "ODO TRIP" buttons down simultaneously.
Hold both buttons down for 7-10 seconds after the ACC mode is on. After the above operation, the master warning light comes on, a warning tone sounds and the above message appears to inform you that the engine oil maintenance data has been reset.
__________________
__________________
