Gs puddle mirror bulb change??
Old 12-02-10, 06:40 PM
JaytdotP
JaytdotP's Avatar
Default Gs puddle mirror bulb change??
Hi, i want to change my puddle lights bulbs to bright LEDS on my 2006 gs 300 mirrors..
how do i do this, and what kind of bulb do i need?
Old 12-02-10, 07:04 PM
RenatUSSR
RenatUSSR's Avatar
You need this kind of bulbs (194)
And they must light forward.
Also you can look mine pics here
Search DIY for IS250 here. (clublexus.com)
The manual is the same for GS/
Old 12-02-10, 10:50 PM
JaytdotP
JaytdotP's Avatar
would these bulbs work??
http://www.v-leds.com/Interior-LED/D...-p5768086.html
Old 12-02-10, 10:53 PM
JaytdotP
JaytdotP's Avatar
i think i need something a little less bright, what would you recommend??
Old 12-03-10, 05:08 AM
worker
worker's Avatar
Duct tape it up.
Old 12-03-10, 08:27 AM
RenatUSSR
RenatUSSR's Avatar
NO! These bubls work great on IS250.
BUT in GS you need another type of bulbs.
Which light only forward, not to side.
In my country people look at my MOD with wide open eyes!
Why you want less bright?
You can easely find cheap bulbs whereever you go.
If you want less bright -
http://www.v-leds.com/Exterior-LED/C...14849-1-2.html
But this would be 4 times less bright (then hi-power v-leds)
So you choose - 25 lm or 100 lm brigthness
another way - to look for leds bulbs, with Luminous Intensity about 50 (lm)
Old 12-03-10, 10:00 AM
worker
worker's Avatar
https://www.clublexus.com/forums/is-...ting-mods.html
Old 12-03-10, 10:11 AM
JaytdotP
JaytdotP's Avatar
why wont the flank bulbs work?
Old 12-03-10, 10:22 AM
RenatUSSR
RenatUSSR's Avatar
But in GS a little bit different.
Flank bulb not necessary as in IS250.
Sorry but with my english I can't explain everything to you.
IS
GS
You must see the difference.
Ok ... in brief...
Flank bulbs - good only for IS250
Just believe me
Old 12-03-10, 10:48 AM
BinaryJay
BinaryJay's Avatar
You can change the bulbs without removing the mirror from the vehicle?
Old 12-03-10, 10:54 AM
skim07
skim07's Avatar
you should be able to find less brighter led here.
http://autolumination.com/194.htm
Old 12-03-10, 11:13 AM
RenatUSSR
RenatUSSR's Avatar
No.
And by the way this is the only easiest way.
Look at my posts here...
https://www.clublexus.com/forums/gs-...ow-tos-43.html
You will have to open the two halves of the mirror covers to access the bulbs, and in order to open them you must first remove the door panels and then the mirrors.
"first remove the door panels" - not necessary!
Not necessary to remove door panels >
In GS even easier to remove mirror then on IS, because you have special places for screwdriver on backside of the mirror.
Old 03-30-11, 03:50 AM
JaytdotP
JaytdotP's Avatar
ive had the bulbs for a while now but i still dont get how to put it in lol.. help anyone??
Old 03-30-11, 05:05 AM
RenatUSSR
RenatUSSR's Avatar
Circle - "Grab"
Triangle - "Clip"
Old 03-30-11, 05:08 AM
RenatUSSR
RenatUSSR's Avatar
Circle - "Grab"
Triangle - "Clip"
You need screwdriver.
And to go with screwdriver in places where triangles in the pics.
Sorry for english.
Quick Reply: Gs puddle mirror bulb change??
