Conversion of Door Lights
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
OEM housing with 2 original LEDs (Color temp 5K)
Not 194 socket !
Maybe possible change to circuit board the whole OEM housing![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
http://www.v-leds.com/Exterior-LED/C...00874-1-3.html
Total Luminous Intensity: 90 lm![EEK!](https://www.clublexus.com/forums/images/smilies/eek2.gif)
Like Hi-Power LEDs
This thing can fit the OEM housing cuz it is small - 16х16x6.5 mm
Like CTRL or ALT button on a keyboard
Cutting wires...
Not 194 socket !
Like Hi-Power LEDs
Cutting wires...
![Rock On](https://www.clublexus.com/forums/images/smilies/rockon.gif)
Not 194 socket !
Like Hi-Power LEDs
Cutting wires...
Not 194 socket !
Like Hi-Power LEDs
Cutting wires...
I ordered them. In package only 1 circuit board.
So I will try to change them all, in all doors![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I think the same LEDs could be found on e-bay with much less price
But I want V-Leds
But I want V-Leds
You mean that you don't want to cut two wires ?
You worry about warranty?
I will make review with photos if do I it.
Hilux111 (09-16-20)
Pics of housing -
In last pics I showed LEDs on chip.
This chip easily can be removed from the housing.
Problem - not enough space for circuit board![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
In the last picture I showed with black lines what should be cut to fit LED circuit board. The width of housing is about 10mm. But V-Leds board is about 16mm. So if you cut where the black lines it could fit there under 30* angle. The yellow lines (object) - LED circuit board..
LOL, i always thought there was more light someplace else because that damn dome light is just good enough to be a mood light and nothing else. This GS has been the weakest dome light on any car ive owned. The first day i got the car i was in search of, where the heck us the real dome light??
Hilux111 (09-16-20)
