what to do with front fender liner(pics),,
12-16-10, 03:03 PM
12-16-10, 03:13 PM
12-16-10, 03:30 PM
Looks like tyre rubbing due to offset and lowering. Can you remove the lining completely or will your tyres still rub?
12-16-10, 03:51 PM
You should be fine. Just leave it, unless its sagging and causing it to rub more.
12-16-10, 04:04 PM
you have about 40% more of your liner than I do!!!
12-16-10, 04:31 PM
exclusive matchup
it's from rubbing and i think overall is ok, except the top part where it seems dangling now
12-16-10, 05:07 PM
its from rubbin before any shavin and cuttin,,,i was little worry about water or moisture gettin in,,,
12-16-10, 05:48 PM
Do like me... put black tape over it. LOL
12-16-10, 07:52 PM
^ just take that liner out already and go lower
12-16-10, 09:38 PM
Looks bad. Probably spraying the fog light harnesses with water and junk but ... mostly it just looks bad.
12-17-10, 03:19 AM
I ve even have even removed some of the bumper bracket that is exposed in your pic
12-17-10, 04:16 AM
just be careful that not too much water gets behind that. should be ok on typical driving. i had mine out and when i washed my car one day i accidently sprayed up into the wheel well and got water in my headlight
12-17-10, 08:41 AM
Quote:
Originally Posted by
ek9vboi
actually not a bad idea,,hahaha
12-17-10, 09:11 AM
Any disadvantages from removing liner completely other than water into headlights?
12-17-10, 10:30 AM
exclusive matchup
i think the lining helps reduce some of the noise, but not 100% sure
