Check Engine and VSC Light
no it didn't just took a lot of gas and lack of power a little.
this seem like a tranny problem..but i dont know I had this problem with my old car if it lack of power and struggling on shifting it was due to coil pack I had to replace 2 of
them out of 6 it was the maxima v6
Tranny
It appears you have 3 issues here........... If I am reading this correct.... your car is an '06 and you have 166,000 miles?? That's alot of miles for an 06, so maybe you need to have it serviced. Fluid issues are a typical cause for the check engine light to come on. Another cause of this, would be your O2 sensors. I have a 98 with 125k miles and O2 sensors is the reason my check engine light is on at the moment. I plan to get this done. As far as the vsc issue, this should be something to do with the speed sensors. That's how I solved my VSC issue. I hope this helps....
Rock
Rock
CLUM
01-27-15 06:47 PM
