Check Engine and VSC Light
Old 12-17-10, 12:18 PM
kdouglas39
kdouglas39's Avatar
Question Check Engine and VSC Light
I have 2006 GS 300. Check Engine and VSC Light came on after car wasn't shifting properly. The codes are P0761 and P2714. Dealer claimed transmission fluid was low said they drain and refilled the fluid. Trnsmission does not have a leak, so I didnt understand why they claimed the fluid was low. Car ran fine for a day then issue came back. The codes refer to shift selenoids. Has any one experienced this issue and what did it take to fix it?
Thanks KD
Old 12-17-10, 12:52 PM
lkapimp216
lkapimp216's Avatar
How many miles are on it ???
Old 12-17-10, 01:01 PM
kdouglas39
kdouglas39's Avatar
Default Check Engine and VSC Light
166K Miles
Old 12-17-10, 01:04 PM
lkapimp216
lkapimp216's Avatar
The trans service is recommended every 60 k does the trans slip
Old 12-17-10, 01:09 PM
kdouglas39
kdouglas39's Avatar
No, it just started hesitating to shift recently.
Old 12-17-10, 01:12 PM
kdouglas39
kdouglas39's Avatar
They say the fluid never needs changing and they don't work on the trans, so all they do is check level. They claimed it was low, so they said they drained and added fluid which I know doesn't fix a shift Selenoid Valve be stuck open or closed.
IXI187IXI
IXI187IXI's Avatar
even though they say the fluid in the trans doesnt have to be changed, it cant hurt to flush and add all new fluid
Old 12-17-10, 01:13 PM
rominl
exclusive matchup
rominl's Avatar
tranny service every 60k? to do what? the tranny is fully sealed, i don't think it's supposed to be touched until after 100k?
Old 12-17-10, 01:14 PM
rominl
exclusive matchup
rominl's Avatar
after 100k miles probably a good idea, that's what my friend told me. but he says the new tranny is all sealed so it's not 60k anymore
Old 12-17-10, 01:15 PM
kdouglas39
kdouglas39's Avatar
They drained and refilled, but that didnt fix issue.
Old 12-17-10, 01:50 PM
lkapimp216
lkapimp216's Avatar
Can you verify that and get back to me cause my service advisor is the one that told me that and I will be approaching 60k in the summer
Old 12-17-10, 01:55 PM
kdouglas39
kdouglas39's Avatar
Does anyone have a clue of what the the fix for this issue may be?
Old 12-17-10, 02:58 PM
supags
supags's Avatar
I remember when I had the vsc light on I had to replace to o2 sensors by the exhaust or something..it was covered by warranty but if it wasn't i would had to pay 1500 or something I can remember it was a expensive job
Old 12-17-10, 03:13 PM
kdouglas39
kdouglas39's Avatar
did the 02 Sensor cause your car to hesitate during shifting?
Old 12-17-10, 03:47 PM
lkapimp216
lkapimp216's Avatar
I have searched for tranny issues on these cars before because in OCD about my car and there is limited information about it on the forum try the search it's been awhile since I have tried it but not to many of us have had tranny issues good luck bro!
Quick Reply: Check Engine and VSC Light
