Problems with lowered gs450h
Old 12-26-10, 10:22 AM
lkapimp216
lkapimp216's Avatar
Originally Posted by RUSSOM
Is this the case with all 3G GS? Do they lean from the factory?
Yep they re lower in the driver side
Old 12-26-10, 10:34 AM
RUSSOM
RUSSOM's Avatar
Originally Posted by designo
Check out my pics with factory 18"s lowered and 20mm spacers!
Great looking car and thanks for your input. So when I'm looking at the pics of your car with the factory wheels, that is with Eibach's 1.5"/1.0" Pro-Kit installed and 20mm spacers?
Thanks again.
Old 12-26-10, 12:05 PM
designo
designo's Avatar
Thanks again.
That's correct sir!
Old 12-26-10, 12:08 PM
passnu2
passnu2's Avatar
yes they do... The 2gen IS has the same issues.
Old 12-26-10, 12:29 PM
RUSSOM
RUSSOM's Avatar
That's correct sir!
Hopefully the 20mm spacers bolt-on? Combined with some DF210s (2.0/1.8), and even with the factory wheels; should be a nice looking car.
I just hope the lean these things have doesn't bother me because I don't want to do coilovers if I can help it.
Thanks for the info. guys.
Old 12-26-10, 01:09 PM
passnu2
passnu2's Avatar
I was on DF springs with OEM rims and spacers and had no issues.
Old 12-26-10, 01:42 PM
*Batman*
*Batman*'s Avatar
I thought it was lower on the passenger side, With the logic that when the driver is in the car, it is level. That's what BMW does.
Old 12-26-10, 04:49 PM
lkapimp216
lkapimp216's Avatar
Why would you not want coilovers, mine ride better than my Tein springs did and springs are harder on your shocks so you ll end up spending the money in the long run plus you will have the ability to adjust the car to your liking. I don t think Ill ever have a car that isn t on coilovers to be honest.
Old 12-27-10, 02:33 PM
designo
designo's Avatar
Thanks again.
That's correct sir!
Here are some pics of my car on stock springs and 25mm spacers! It was a disaster honestly, the car was shaking violently at speed above 50mph. Not safe at all!
Old 12-28-10, 07:04 PM
RUSSOM
RUSSOM's Avatar
So 25mm was a disaster, but 20 mm was ok? Were both hubcentric and bolted down squarely? FWIW, I've always had good luck with H&R spacers.
From what I can tell from the pics, a 20 on the front and a 25 on the back would probably look perfect.
djpeakSD
01-07-13 02:10 PM
panda_ek9
Suspension and Brakes
09-25-11 10:22 AM
SptDsgnGS
07-08-09 12:12 PM
Lexo_Tony
21
01-07-09 09:01 PM
turbodremz
02-01-08 03:52 PM
Quick Reply: Problems with lowered gs450h
