Will removing wheel lock cause alignment issue
Old 12-23-10, 10:48 AM
designo
designo's Avatar
Originally Posted by rominl
putting them on carefully and then tq down is good. taking them off by airgun, nothing wrong with it
I have always beleived in your take on these issues! You are absolutely right, in most cases problems ( vibrations, shaking, wobbling ) are due to torquing of wheels lugs!
Everytime I re-torque my wheels back on with spacers, the shaking either goes away or gets worse!
My 10mm spacers caused shaking at various speeds. Once the wheels were removed and re-bolted back on by hand in a star shaped manner, the shaking went away!
Old 12-23-10, 11:23 AM
rominl
exclusive matchup
rominl's Avatar
yup, especially with spacers it can get ever so sensitive. that's the case for my m3. i have spacers on the car, and every time it's back from dealership, it has vibrations. then i jack up the car and re-tq everything, everything goes away
it tells you something (sigh, dealerships...)
Old 12-23-10, 12:27 PM
Ice350
Ice350's Avatar
Originally Posted by bigblack06
yeah I would go with unbalanced tires, trying going at high speeds, if you feel a vibration i would say its the tires that need to be balanced.
Unbalanced tires have nothing to do with the alignment.
Unbalanced tires will result in vibration, not pulling.
Old 12-23-10, 01:10 PM
I8ABMR
I8ABMR's Avatar
Originally Posted by IXI187IXI
you dont need an alignment after a tire change. you only need an alignment when removing major suspension items like struts/shocks that connect the arms or knuckle to the steering.
I just a had a set of 22's installed on my LS last week and ever since the car pulls to the right. I am going to have them do an alignment very soon. This pulling could be normal. Discount tire is great for price but the balancing sucks and they also broke a wheel lock on my G35. They tried to send me into the ghetto to have it fixed at their cost but I said hell no, this car is only serviced at a dealership where I can get a loaner. I do not sit in waiting areas for anything After my issues with discount tire I now take my car close to 50 miles away from my home to have my wheels and tires installed by wheel specialists. The service is great but for some reason I can never get a decent balance from any shop no matter what. I would say out of 20 sets of tires maybe one set will be balanced the right way and did not need a return visit
Old 12-23-10, 01:15 PM
IXI187IXI
IXI187IXI's Avatar
^ what type of balancing are you getting?
Old 12-23-10, 01:45 PM
bigblack06
bigblack06's Avatar
I know thats why I said if its vibrations I would blame that.
Edit:Yeah thats my fault though he spoke about vibrations thats the reason I spoke of the unbalanced tires.
Old 12-23-10, 01:46 PM
IXI187IXI
IXI187IXI's Avatar
a bad dynamic balancing can result in pulling
Old 12-24-10, 03:08 AM
jre002
jre002's Avatar
Probably radial pull from a defective tire. It's happened to me once or twice when I bought new tires. As some suggest, try rotating the wheels and see if that helps. If not, you should have them replace the bad tire.
Old 12-24-10, 06:51 AM
lkapimp216
lkapimp216's Avatar
Its probrably the tire ruts in the pavement pulling the car, certain tires do this worse than others
Old 01-18-11, 04:41 PM
electron
electron's Avatar
Thanks everyone for the suggestions
brendanf
RC F (2015-present)
04-01-19 11:36 AM
sdwtchlvr
12-11-18 03:40 PM
stick22
12-27-12 09:41 AM
dlap
09-16-09 07:30 AM
artbuc
RX - 1st Gen (1999-2003)
18
08-04-09 10:03 AM
Quick Reply: Will removing wheel lock cause alignment issue
