V-Leds in Parking, Puddle & Reverse Lights
#166
Its really not that confusing. You have two bulbs in the smaller (high beam) housing. the big bulb in the middle is your high beam but it also doubles as your DTR light (at half the voltage output)...now in the top corner of that same housing you have your city lights which go on when your headlights are on...this is what people are replacing with LED.
#168
when you are riding around during the day time you should see your inner lights on (by inner lights I mean the inner headlight housings)...these lights are halogen and they are your day time runners...HOWEVER they also double as your high beam light. Thats right one bulb is both your DTR and your high beam (the DTR runs at half the voltage)....the city/parking lights are also halogen and are in the SAME housing at the very top corner. Now the big headlight housing (outter) is where your main headlight is which is obviously a HID bulb. A lot of people dont like the look of hte halogen CITY LIGHT in junction with the HID headlifht so they replace the CITY LIGHT with a LED light. The turn signal is in the main (outter) headlight housing. I HOPE this clears it up.
#169
#170
huh?? the DTR is on when your headlights are OFF and you are driving around during the day. the small inner housings should be lighting up. The city lights go on when your headlights are on at night, at this point your DTRS are off.
#171
So if you change out your DTR's with LED's, do you lose your high beams??
#175
#176
#177
nope...youre gettin it confused since BOTH BULBS are in the same housings....the bigger middle one is your DTR (and high beam) and the smaller one in the top corner is your city light that goes on when your headlight is on....they are in the same housing and one of them is always on so its easy to think that its the same bulb BUT its not....I replaced my city light with an led so it matches my 6000k headlights...my DTR is still a halogen bulb that is on during the day (I didnt change this to led cuz I still want use of my high beams)
#178
#180
lol thats not ambur thats just halogen...looks yellowish next to the HID headlight...thats your city light....you can see the amber bulb right next to your hid headlight (same housing as the headlight)
