Upgraded Brakes to 4-Piston Caliper!
Old 01-05-11, 04:49 AM
bigblack06
bigblack06's Avatar
Post Upgraded Brakes to 4-Piston Caliper!
Hey all had a question, I'm about to purchase the new caliper on the 07-11 GS and want to know what I really need to change aside from the rotors, brake pads. In other words do I need to change the dust shield and the brake lines, etc. please help want to purchase what I need!
Thanks in advance!
Old 01-05-11, 05:54 AM
designo
designo's Avatar
So our 3GS OEM calipers are 4 pot?
Old 01-05-11, 06:27 AM
LexFather
Guest
Posts: n/a
1GS 2 pot
2GS 2 pot
3GS 300 2 pot
3GS 350/430/450h/460 4 pot
The difference in size is pretty staggering and obvious. Not sure about dust shield/lines but I would think so, the brakes are substantially larger.
Old 01-05-11, 07:58 AM
bigblack06
bigblack06's Avatar
no they are 2 Pot and I want to upgrade them to 4 Pot, I know someone did it on this site but wanted to know if I needed to install all of that.
Old 01-05-11, 08:25 AM
TWong350
TWong350's Avatar
As 1Sick stated:
3GS 300 2 pot
I believe you need to change not only the calipers and rotors but the brake lines and dust shield. I can't see how the larger rotor would play nice on the smaller dust shield on the 300.
Old 01-05-11, 08:57 AM
rominl
exclusive matchup
rominl's Avatar
not sure about brake lines, but dust shield i am pretty sure is different
Old 01-05-11, 09:05 AM
bigblack06
bigblack06's Avatar
alright I will get the dust shield and will order the brake lines just in case! thanks all!
Old 01-05-11, 09:11 AM
Sffd103
Fire Slayer
Sffd103's Avatar
When I installed my aftermarket BBK, I just removed the dust shields, but since you're going with an OEM bigger brake you'll probably want them cause they do fit.
Old 01-05-11, 09:26 AM
bigblack06
bigblack06's Avatar
you talking about the brake lines or the brake shield
Old 01-05-11, 10:05 AM
KayGee
KayGee's Avatar
A word of caution: if you have a 2006 GS300 with custom wheels that were made specifically for that car you will not be able to reuse the wheels once you change the rotors without modification. The hub hat on the 2007+ GS is significantly thicker.
I purchased a set of custom wheels off of a 2006 GS300 and they would not fit on my 2007 GS350 without longer studs. I ended up selling them for a $200 loss.
Old 01-05-11, 11:00 AM
rominl
exclusive matchup
rominl's Avatar
if you are ordering them, why not order the setup through sewell? they have the setup for pretty good price
Old 01-05-11, 11:24 AM
bigblack06
bigblack06's Avatar
Cause my dealership is only charging $456 for the dust shield and the calipers so I'd rather save the couple dollars and get it right away!
Old 01-05-11, 03:10 PM
ek9vboi
ek9vboi's Avatar
Skip the dust shields and get SS brake lines if your going to change them out.
Old 01-05-11, 03:24 PM
GS350Lexus
GS350Lexus's Avatar
Try using the search i remmember someonr upgraded to 4 pot on a gs300 with pictures. Im on my iphone i can't search.
Old 01-05-11, 05:27 PM
bigblack06
bigblack06's Avatar
yeah I searched it was cpcalkins but he did not say whether he had changed the brake lines only that he got the full kit from Sewell Parts.
Edit: I'm a dodo bird, just re-read the post he changed everything out except the brake lines which he re-used, my fault guys, thanks GS350Lexus
Quick Reply: Upgraded Brakes to 4-Piston Caliper!
