Another MPG Thread
Old 01-16-11, 08:03 PM
charmz
charmz's Avatar
Default Another MPG Thread
Im not sure if something is wrong, or if its the way Im driving, but my gas mileage sucks!
Mixed driving highway 40% and city 60%.
My computer says Im getting 11.1 L/100km = 21.19 mpg, but it lies.
When I crunch the numbers (70 liters = 554 km) = 12.64 L/100km = 18.61mpg
100% stock, 300 AWD, 100,000 km (62,000mi), proper psi in tires, 91 octane gas, synthetic blend oil every 5000km, clean air filter and just had injector flush done and new plugs put in.
It seems like after I did the flush and new plugs my mpg went slighty down also!?
Any suggestion of what I can do? is there something im missing here.
Tried the PWR mode after reading a thread that it helped mpg but made mine way worse, briefly tried SNOW mode but find it too annoying to have to push the button everytime I start the car. Between the insurance and gas money I put into this thing, Im starting to seriously debate if I can afford it anymore.
$90 ($1.26ish/L) of gas to get 550 km sounds ridiculous to me.
Old 01-16-11, 09:32 PM
GS350Lexus
GS350Lexus's Avatar
Ummmmm I am getting 11 MPG, 2007 AWD GS350 new plugs,new filter, synthetic oil, etc etc etc. Its all about where you are located, and how heavy you are on the gas pedal. I live in NYC so when i see it says 18MPG city, I look at it more like 10MPG city. If you car drives smooth, normally, cranks from 1 start, doesnt have white or black smoke coming from exhaust pipes then you don't have much to do.
Old 01-17-11, 01:16 AM
rickyb80
rickyb80's Avatar
Depends on how you drive it. My best tank thus far has been 28.6 MPG's (almost all highway) and my worst has been 20.2 MPG's (mostly city and agressive driving).
Old 01-17-11, 05:44 AM
nehal51086
nehal51086's Avatar
Your driving a 450H, we get considerably higher mpg than the 350 and 460.
Old 01-17-11, 06:19 AM
JL6speed
JL6speed's Avatar
I'm getting like ~24mpg after the valve spring recall. 70% highway 30% local
Old 01-17-11, 06:30 AM
BinaryJay
BinaryJay's Avatar
Wouldn't you always have white smoke coming from the exhaust pipes when it's cold out? Wouldn't it be a better test to see if you are losing coolant or oil by checking the levels on these?
Old 01-17-11, 10:08 AM
RenatUSSR
RenatUSSR's Avatar
18 MPG now in winter.
13 MPG was in summer.
Best result 20MPG - first ride from dealer to home
p.s. i have also L/100km, but I just used online converter.
You can use cruise control on highway.
That's how look L\100km on IS250 after cruise control >
Very nice "L/100KM", like hybrid car
Old 01-17-11, 12:47 PM
ARCHIE450h
ARCHIE450h's Avatar
Hello All,
I just purchased my 2007 GS450h this past Wednesday. I have yet to get an MPG reading over 23.0 MPG. Can someone let me know if my settings are correct?
Should I be hitting the hybrid switch? What does that do anyway?
Thanks and any help will be greatly appreciated.
I am happy to be a part of such a group!
Old 01-17-11, 01:05 PM
niteflite
niteflite's Avatar
on a 2006 awd, i've been averaging 20.5 - 21 mpg in 70% city, 30% hwy. this is without driving aggressively or accelerating quickly.
on 100% local i think i get 17 mpg. but this was constant stop & go traffic and many minutes sitting idle.
i know once on straight hwy, over 250 miles i got 28.5 mpg or so cruising at 60 mph due to spare tire
but i see the mpg dropping by .1 for every 30 seconds i sit idle at the traffic light.
i think at my prior job when it was 70% hwy, 30% city, i was getting 22.5 mpg.
i have to admit this is one of the main causes, if not the main cause, of my buyer's remorse.
Old 01-17-11, 01:49 PM
charmz
charmz's Avatar
are you guys referring to your mpg as what the car tells you it is or what you have calculated using fuel used and distance traveled?
because my car display always tells me my mpg - l/100km is higher then it really is.
im not driving aggressive at all, rpm never over 3000 on highway or 2500 on city roads.
that 18.6 mpg was a better then average tank since it was mostly highway, and i dont understand how doing an injector flush and new plugs would make your gas mileage WORSE.
i bought the car with an understanding that i would be getting 21-22-23 mpg which i would be okay with, now dissapointed that im getting more like 16-17-18.
even when i fill the tank up now it always says something like "520 km to empty" (even though thats never right) when before it used to be in around around "600 km to empty"
Old 01-17-11, 01:54 PM
Rider
Rider's Avatar
Ah 550km! I get 360km!... but I pay $15 for 70 liters
Old 01-17-11, 03:35 PM
cowsgomoo
cowsgomoo's Avatar
During the Summer I will average 14-16mpg TOP. I have a 50/50 mix of city/highway.
Currently get about 15-17 depending on how heavy of a foot I have or how much idling I do.
This is for a gs430. I like to use Techron fuel system cleaner every 5k, I will see about a 1mpg gain each time I use this.
Old 01-17-11, 04:26 PM
bigblack06
bigblack06's Avatar
Great numbers i wish I got those I get around 13.5mpg city and 21mpg on highway when I try to use in winter, In summer I get 18-19mpg in city and 23.5mpg on highway. I wonder the same thing if the dealer planted something in the car so when you drive it looks great on gas but hocus pocus magic and you get a car with worse gas miles.
Old 01-17-11, 06:55 PM
mmade22
mmade22's Avatar
Non-hybrid but doing my best to see what this car could do. 70 degrees, no a/c on and going easy on the car...All hwy 400 miles into the tank.....
Old 01-17-11, 07:45 PM
niteflite
niteflite's Avatar
my #s are according to the trip computer. i just put in 9 gallons into my tank the other day. i wrote down the # of gallons and the odometer at the time. we'll see what the actual mpg is.
Quick Reply: Another MPG Thread
