UAS Installation
Old 01-24-11, 06:37 PM
wwong510
wwong510's Avatar
Default UAS Installation
Was wondering if anyone knew someone or a shop that specializes in installing air suspension. Specifically Universal Air Suspension products.
My UAS kit arrived last week and looking for someone to help me put it in around the East Bay area. I am willing to commute about 50 miles out of Oakland, CA.
Also my budget is around $6-700.00. Anyone have any recommendations? Or can vouch for someone or a shop?
Thanks!
Old 01-24-11, 07:42 PM
tuandang79
tuandang79's Avatar
Hey you can hit up Sonic MS in Mountain View, (650) 733-6506. talk to Darwin.
Let him know Tuan referred you.
My GS430 is there right now getting air put on for the next few days.
Old 01-24-11, 07:47 PM
wwong510
wwong510's Avatar
Will do, Thanks for your help!
Old 01-25-11, 04:01 AM
IXI187IXI
IXI187IXI's Avatar
keep in mind the rear struts have to be modified so you may be looking at more than 600-700 for install.
Old 01-25-11, 04:19 AM
johnnunez2
johnnunez2's Avatar
i was told nothing realy had to be modified. they did say someting about having to attach a bracket to the struts but thats about it. the dude even said it was easy. idk , i might attempt to install this myself. btw, congrats and please tell me how you like the system when its installed. im getting this in a couple of weeks aswell.
Old 01-25-11, 04:35 AM
IXI187IXI
IXI187IXI's Avatar
another member talked to Zack over at UAS and this was his response, it seems pretty similar to the 2nd gen GS setup
I just spoke with Zack he told me that we would have to modify the rear strut and seems pretty involved. I would need to make a custom bracket to lower the bag down further on strut and fabricate some sort of spacer for the top so it would fit is how I understood it! Im have very little knowledge of air suspension.
Old 01-25-11, 06:52 PM
wwong510
wwong510's Avatar
Thats funny. Zach from UAS told me the top perch from the front strut needed to be cut and ground down. He never stated any modification to the rear.
However, I spoke with TuanDang (cl member) briefly, whom is in the process of installing his UAS in his 3G GS and he said something in the rear needed to be modified.
Can someone discuss this that has already installed this system in their 3G.
For clarification, I will be running my system on stock shocks. I was also offered a set of modified brackets from Zack of UAS. Opposed to the standard brackets. He claimed that the modified bracket allows me to go lower in the front.
Old 01-25-11, 09:03 PM
alwayzspeedin
alwayzspeedin's Avatar
Impact Performance
2259 Shafter Ave
San Francisco, CA 94124
(415) 602-5338
Hours:
Mon-Fri 9 am - 7 pm
ask for carlin he's doing my UAS right now go check out my 3GS....tell him TIM/alwayzspeedin from clublexus sent you..he'll hook you up
Old 01-25-11, 09:30 PM
chiu_888
chiu_888's Avatar
The rear shocks and front shocks do need modification to fit the bags on the stock shocks so it can sit lower if not then the car will still sit pretty high if you just put the bags over the shocks as is
Carlin
Old 01-26-11, 03:52 AM
johnnunez2
johnnunez2's Avatar
damn this is frustrating. eveyone says something different.
Old 01-26-11, 10:49 AM
chiu_888
chiu_888's Avatar
you can put everything together as is but you will find that the car doesn't go very low without modifying the shocks, but UAS can make it go even lower by sending them your shocks and they will cut out the spring seat completely and weld on a completely new bracket and thats an option from UAS for in house modification only, hope this helps.
Carlin
Old 01-26-11, 11:03 AM
alwayzspeedin
trust what carlin is saying cause he's doing that right now on my car go check it out stop listening to people and go see for yourself ......also dont forget to rub carlins bald head for a extra 2% off...hahahhaaha
Old 01-26-11, 12:17 PM
IXI187IXI
IXI187IXI's Avatar
well if you look at what he wrote, the 2 answers technically are correct. the problem is if you do not modify the struts then you can not slam the car
Old 01-26-11, 02:48 PM
swtjlsy
swtjlsy's Avatar
Why would you buy this kit if you have to mod the system to work on your car? Just spend the extra money and go Air Runner
Old 01-26-11, 03:08 PM
alwayzspeedin
you only need to mod if you are using your stock struts, but if you go with tein , hks ..etc they have brackets for it..then no modding with be necessary
Quick Reply: UAS Installation
