My alignment guy told me to do the following...
If I drill the holes, he will be able to adjust camber for my front tires. There is nothing he can do for the rear though. I took a pic and labled things, take a look, let me know if this is safe?
This is tricky work and not sure if I would want my car cut up like this.
I thought they were different when I was working on the car The rear, #2, is different then the front. Let me see if I have any pics that I kept that would show. Maybe Im thinking of something else.
He also told me that you can adjust camber on IS / ISF. So, if IS is based on GS, would not those parts be the same or similar? Maybe we could just replace the part instead of drilling holes
2is and isf do not have camber adjustment as far as i know. there are camber kits for those cars, and mike already have those installed on his car
thats my only concern. any type of slotted connection (like hes suggesting) is typically designed for movement like expansion and contraction hence why its slotted. i wouldnt trust things staying in place using this method.
Why... there are shops that can correct some of the 2"+ drops by adjusting the toe. Wear is almost perfect across the tire. Yes, it requires bending the arms and so on, but I think its a safer bet then doing what was suggested above.
vwynn
Suspension and Brakes
06-05-09 05:03 PM
