Air filter selection and install
Hello Fellow GS 300 owners,
I'd like to know if there is a preferred air filter that I should use for my 2006 GS 300? I also referenced the install procedure on this forum and will be using it once I chose an air filter. Thanks in advance for your help.
Under the hood or behind the glove box?
I'm using K&N under the hood. Car too new to even worry about the glove box filter...but will go OEM when that time comes.
It literally took me maybe 5 minutes to take the old one out and put the new one in my 2006 gs300. Mine is through the glove box. Easiest job ever and saved myself $60.00 at the dealer. (cabin filter that is)
if you're reading the instructions on this forum for cabin filter....... just make sure you set the a/c to recirc.
if you can't directly see the air filter when taking the panel off, you're doing it wrong.
2006 gs300, 2009, air, air filter, drivers, es350, filter, install, installation, installing, lexus, selection
