"Dead" Steering Zone At Higher Speeds
Hello. This is a weird one and I could use your expert advice.
This past week was the first time I've had the GS up to a consistent 80+ mph on the interstate. Above 75 or so a very strange "dead" or "stiff" spot occurs in the center zone of the steering arc, about three or four inches. In this zone there is real active stiffness in the steering wheel. The problem is, when you exert sufficient pressue on the wheel to "break" out of that zone it immediately goes to the normal stiffness, so there's a natural overrcorrection. Frankly, it's dangerous and frightening. I've never experienced this on any car I have owned.
My guess is either alignment or a power steering issue. The tires are basically new and were properly inflated. It's not natural reduction in power steering at higher speeds, one thinks, because it is not consistent.
The car goes in for service later today, because I didn't want to mess around with this. But it's troubling and I would, as I said, appreciate your advice. Thanks.
how many miles are on the new tires? did you go from a summer hi-performance tire to something less aggressive (touring, etc)?
could be new tire squirm or just a softer widewalls of the new tires causing some dead on-center feel.
if you had uneven tread wear on the last set of tires, that could be a sign for an alignment
Has the steering rack "recall" been performed on your car? I say "recall" for it was really a "service campaign" to take care of a problem with the electric steering system.
No, as Johnson Lexus is backed up on that until May. The service guy did mention that though.
M
M
I don't know exactly. I have only had the car a month. I suspect it might need an alignment.
UPDATE: Johnson Lexus reports that one side of the front is riding about an inch higher than the other. I have to take the car in next week and leave it with them.
I asked what could cause this and the guy speculated, "an impact" - and the service records indicate that the control arm had been previously replaced.
Thus, I suspect I've been sold a car that hit something. I guess I will find out whether this is a few hundred dollar item or whether I will need to consult an attorney.
It's very much a buyer beware case. And by the way it's my understanding that it is perfectly natural that the passenger side of the car is slightly higher than the drivers side when nobody is sitting in it.
Unfortunately when you buy a used car, it's impossible to prove that the person who sold it to you would have had prior knowledge of an accident and lied about the car's status, especially given a clean report, unless they were the only owner.
Simply put, if they knew about the damage and failed to reveal it to me when I asked about prior wrecks and damage, it's an unfair trade practice.
Hopefully this is a matter of a couple of new shocks, given the car has a clean Carfax.
Wow...I am so glad to hear that someone else has the same problem. I have had this for about 2 years now and the dealer tells me that they cannot reproduce the problem.
It is downright dangerous and scary when you need to make a slight correction and have to put some muscle into it to make the correction.
I never really new how to explain the problem which you have done accurately above.
On another note i bought mine new and it has never been in a collision so I know for sure it is not from an accident.
Let's see what they say but hopefully they take it seriously as I could see something like this causing accidents.
NC, if this car has been involved in an accident it's possible (albeit unlikely) that the dealer didn't know about it. I think you need to have a discussion with the dealership before you resort to engaging an attorney. This sort of thing has a funny way of working out once you get to the right level at the dealership and we have too many lawsuits as it is. I feel your frustration but let the management of the dealership try to make it right.
Just a quick update. I took my car in yesterday for the steering issue stated above and they were able to reproduce the problem and will be replacing the steering rack under my extended warranty.
I am glad to see it is covered as it looks like a new rack online is around $1500 just for the part.
It turned out the car had suffered serious damage from a pothole incident that had not been properly fixed. I got a DMV report showing the insurance claim. The repairs involved replacing pretty much everything at the front end on the relevant side. About $3500 I think. The car is now fine.
