Tire rod problems??
Tire rod problems??
I've only had my car for 2 months and I'm already experiencing a few minor (fingers crossed) problems. This go round involves noise from the front drivers tire. At low speeds it sounds like I'm running over a chain sporadically. Haven't noticed it at high speeds but sometimes on flat surfaces and sometime while going over speed bumps. My guess-estimation is tire rods might need replacing. Any advice?
A bad tie rid will usually cause the steering wheel to shake, and a wheel bearing will usually make a humming sound and be constant. Could it be your brakes?? Maybe the pads vibrating. I actually had a rock stuck in the rear drum part of my parking brake that was rattling around and making a grinding noise occasionally. I had it removed last week
djkneekap
05-03-11 07:30 PM
purebliss
04-09-05 02:51 PM
