20inch rims /turning issues??
03-31-11, 08:43 AM
exclusive matchup
Quote:
Originally Posted by
-the.k.w.c
how many mile/km are u boys getting out of a 30 series tire??
i have 245/30/20 up front and lowered quite a bit. i get about 30k miles on my tires
03-31-11, 04:07 PM
lkapimp216
If you go with 19s you can use a 245/35-19 and a 285/30-19
Ok thanks guys..so that's the tire size for front and rwd right?
03-31-11, 07:40 PM
supags
Yes sir!!!!
03-31-11, 07:42 PM
rominl
You think Ill get 30k out of mine??? lol!
03-31-11, 11:36 PM
exclusive matchup
lkapimp216
all depends on driving AND toe settings
04-01-11, 03:19 AM
-3.5 camber in rear -3.0 front and the toe is within factory spec .13&.15 spec is .4-.20 I ll be happy with 20k
04-07-11, 01:00 PM
IXI187IXI
just keep in mind that a 245/30/20 is not the same overall diameter as a 275/30/20
if your doing a 245/30/20 up front, then you need a 295/25/20
a 295 may not fit but the next closest is a 285/25/30
This is exactly right. 275/30's are a lot taller than 245/30's,
295/25 w/ 245/30 is almost exact......not sure if you can fit 295's on a 10 inch rim though. Can you?
02-11-14, 11:53 AM
I believe a 20x8.5 / 20x10 setup with 245/30/20 in front and 285/25/20 in rear will work on my 2004 GS300. Please confirm, thanks.
C
02-11-14, 12:23 PM
You're in the wrong section czr, might wanna hop over to the 2GS section
02-11-14, 01:10 PM
loccsta187
04-06-13 04:02 PM
mynes09
03-21-12 06:14 AM
jnemo
IS F (2008-2014)
04-15-11 11:08 PM
IronCobra
09-05-08 09:23 AM
upstateGS4
Wheels, Tires & Brakes Forum
03-10-08 11:19 AM
20 ,
2007 ,
2453520 ,
2852520 ,
es330 ,
gs ,
hs250h ,
inch ,
lexus ,
lowered ,
problem ,
rims ,
rub ,
rubbing ,
wheels
