Just received my custom built 3pcs wheels offsets are 30 in the front 20x9 and 35r 20x10.5 tires 235/30/20 front and 255/30/20 lower on Ksport coils and have no issues so far.
I ran 295/25 in the rear and 255/30 up front with no issues. but tire size is only a piece of the equation. just do your homework and use the thread we started more then enough info for anyone
what you guys think I should use for my 19s? to avoid any damage and having a smooth ride.
Front: 245/35/19 or 235/35/19
Rear: 275/30/19 or 265/30/19
what you guys recommend? just want to know the best advice here.
thanks
the 245/35 and 275/30 would probrably keep you closer to factory spec but the 235/35 and 265/30 would give you more clearance if your worried about rubbing the fender edge.
