sunroof water leak
Hey guys I just noticed...when ever i go through car wash I'm seeing little water draining from the up & down part of the sunroof leaking water from both corners. The sunroof is fulled closed. How can i drain the water out? anything i should be worried for?
Keep your weatherstripping clean and lubricated. This is something it seems like almost nobody does as part of regular maintenance of their cars. You should be wiping weatherstripping down with silicone every so often.
can someone tell me where I can drain the water out? or is it already drained out? I don't want the water to be inside the car
anything I should be worry about here?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
jmeade
09-21-18 10:01 AM
