Refinish Center Console Wood
Anyone know of a vendor that would refinish my console wood. I see a lot of threads about self refinishing, but would like a professional to handle this one.
Let me know if you have any ideas.
Thanks in advance.
Thanks in advance.
Sorry, I should have clarified.
I am looking to restore the look. Remove scratches, etc.
I was able to pick up an 08 console cheap for my 07 and may need to do a little work on it.
The coating over the wood is just a clear coat similar to what is on the outside of the car. A good detail shop should be able to polish it using a buffing compound and some wax. The hardest part is keeping the wax off of the leather surround and out of the cracks, but if it is not installed yet it should be really easy.
just pull it out out. very simple to un-install, clean it up and put it back. there's a sticky on here on how to get the console up.
Treat it like you would your clear coat on the exterior paint... if one buffing compound doesn't work, then use one with more grit to it, follow up with a finer buffing compound, then wax it.
