Help with vais sl2ic
Just a quick question. Don't know if you remember but I was installing sl2ic and was having problems with e climate control. Turns out I blew a fuse. Just wanted to make sure I did it right this time. Do I only plug in 2 connections from the vais to the head unit. The blue DVD line and the 20 pin on the top of the nav. Unit. Last time I plugged the y shaped into one of the bottom slots and then connected that to the vais unit marked to the head unit. I take it that was wrong.
