ANOTHER ONE!! IM Sure this has BEEN discussed!! GS350 AWD Wheels
Old 05-26-11, 04:17 PM
Iconisme35
Iconisme35's Avatar
Default ANOTHER ONE!! IM Sure this has BEEN discussed!! GS350 AWD Wheels
I just bought a GS350 AWD and I would like to put some wheels on it. I'm thinking about 20's but I want a staggered set, and I've been told since its AWD it will mess up my drive, traction control and all that other stuff. Ive looked on here and seen couple of AWD's with staggered sets. CAN ANYONE HELP!!! Some advice on offsets and tires would be awesome.
Old 05-26-11, 04:33 PM
rominl
exclusive matchup
rominl's Avatar
welcome to clublexus
just search on my posts before on awd staggered setup then... key is the overall diameter, as long as they are close, you are fine. for example 245/30/20 and 285/25/20, they are perfect match.
Old 05-26-11, 06:07 PM
lkapimp216
lkapimp216's Avatar
Nuff said !!
Old 05-26-11, 07:39 PM
GS350Lexus
GS350Lexus's Avatar
How does 245,30,20 in the front and 285,30,20 is the same? 245 is the width of the tire, the higher the number the longer in width it is. 25 stand for height (aka thickness of the tire). So the difference between the specs you mentioned is +40,+5,20. Not sure how the thickness of the tire has anything to do with the width of it.
Old 05-26-11, 09:33 PM
excluesive
excluesive's Avatar
the 30 in the tire size is the % of the tread width. That equals sidewall height
Old 05-26-11, 09:54 PM
Iconisme35
Iconisme35's Avatar
thanks for the help guys!!
Old 05-26-11, 11:01 PM
rominl
exclusive matchup
rominl's Avatar
read carefully on what i typed. i said 245/30/20 and 285/25/20, NOT 285/30/20.
the first number is width in mm
the second number is profile (thickness) of the tire, but this is a ratio (%) of the width, which is the first number
the third number is the diameter of the wheel it fits on, in inches
here's the math:
245/30/20, profile of tire = 245 x 0.3 = 73.5mm / 25.4 = 2.89" x 2 (2 of them) = 5.79" + 20 (diameter of wheel) = 25.79"
285/25/20, profile of tire = 285 x 0.25 = 71.25mm / 25.4 = 2.81" x 2 (2 of them) = 5.61" + 20 (diameter of wheel) = 25.61"
from the math, the difference in overall diameter of the wheel setup front and rear differ by < 0.2". that's very close with each other
and like i said, the overall diameter is the key, not the width of the tires. hope this helps
Old 05-26-11, 11:20 PM
designo
designo's Avatar
here's the math:
Thank you brother, that was some great info right there!
Old 05-27-11, 04:33 AM
excluesive
excluesive's Avatar
here's the math:
Good stuff... simple concept, but its amazing how many people don't know what the numbers in the tire sizing mean.
Old 05-27-11, 06:29 AM
MrLugo80
MrLugo80's Avatar
Have any of u guys ever had ur warranty void cuz of stagger wheels on an awd.
Old 05-27-11, 08:29 AM
rominl
exclusive matchup
rominl's Avatar
you guys welcome, more than happy to share what i know!
Old 05-29-11, 08:51 PM
Iconisme35
Iconisme35's Avatar
thanks for the feedback guys, all the advice has been very helpful!!!
Old 05-29-11, 08:59 PM
Iconisme35
Iconisme35's Avatar
im thinking of running 9. in the front and 10's in the back but most of the ones on here have have 8.5/10 or 9.5/10.5 but these usually require shaving the fenders and so forth. So whats the best options to avoid rubbing, and liner issues?
Old 05-29-11, 09:05 PM
msgs350
msgs350's Avatar
This depends on if you lower your car and how much. Don't forget about rim offsets. I have an AWD lowered almost 2" and run 20x8.5" +40 in the front and 20x10 +40 in the rear and don't have any rubbing issues and i didn't have to touch my fenders at all. Tire selection is very important also as some have a wider "shoulder than others.
Old 05-29-11, 09:48 PM
swagga89
swagga89's Avatar
thanks rominl...great explanation
Quick Reply: ANOTHER ONE!! IM Sure this has BEEN discussed!! GS350 AWD Wheels
