auto headlights stopped working... help!!
Ok, so I was using a multimeter to check which wire would provide power to some aux lights and now my auto headlights feature doesnt work. It is the only thing not working. I can manually turn them on without any problems. I disconnected The negative terminal from the battery for 60 seconds to reset the system but that didn't work. Any Ideas? Is there a fuse I could have blown? I'm confused.
I was a certified MECP installer for 7 years and have quite a bit of 12vt knowledge, so I didn't go at this Ignorantly. any help would be great. Thanks.
Ok guys, I really need help with this. Is there a Auto Headlight relay? fuse? something I can check to see if it needs reseting or is blown?
1. Is there a fuse for the Auto Headlight feature?
2. Is there a way to reset or unplug and plugin the socket?
I've already removed the battery cable for 60 seconds and reset the car with no success.
Any help is great needed.
Thanks!
Thanks!
