Design Defect? Nav screen not returning to original screen after parktronic screen...
Hello, i have an 06 gs300 and i don´t know if this beahavior is a design defect...
When i´m for example listening to music and the park assist goes on a splash screen of my car show´s in the screen indicating the near obstacles.
Ok, all good.
But when park assist returns the screen always shows the nav-map screen.
This is not logical to me, if before i´m on the audio or climate screen, what´s the reason the car ALWAYS return to map mode screen??? Is this configurable in any way?
Excuse for my poor english, í´m spanish owner and i don´t talk english in good way...
Thanks.
Ok, all good.
Thanks.
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I try to explain again my problem. If i´m in the audio screen, and i found an obstacle, the screen then shows the park assist screen; then when the obstacle dissapears, the park assist screen goes out, but my system doesn´t return to the audio screen, instead always goes directly to the "map" screen showing my position in the map.
This is annoying for me...
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
There is an option cAlled, automatic transition from audio/air confitioner to navigation/etc. That has nothing to do while in audio n parking sensors come on and bak to default nav screen. There is no way around it OP thats the way it was designed. What you can do is disable parking sonar display on the screen. I wouldn suggest it bu if it bothers u thay much its basiclly the only choice you have.
I´ve searched the menu´s of my 4th gen navi and i haven´t found any option regarding this... Do you know under wich menu is and what´s the exact name of the setting?
This is annoying for me...![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Spoiler
