Maintenance at 140,000km?
Uh, it's in the users manual as well as on lexus.ca.
Spark plugs would have been due at 96,000 km so I doubt they are due at 140k. I don't remember what car you have but unless it's the 430 then there is no timing belt.
There is no reason to replace a water pump unless it's not working.
gs 300 awd.... so the sparkplugs should've been changed?
You bought a used car and drove it 30K without even knowing what regular maintenance has been done or needed to be done? Pretty brave.
You shouldn't be this careless to your car because it can break down like any other machine. Pretty sad if you didn't even change the oil.
