On my 07 GS350, I have all my wife's settings set to #1 and mine are set on #2. Every time I get in the car, it always goes to her settings. I hit #2, everything goes to my settings, and when I go somewhere, unlock the car to get back in, it goes back to my wife's settings. Is there a way to stop it from always going to #1 settings or is that the default?
I believe it is tied to the key fob. I think you can get your second key fob to remember your settings (#2). Should be in the manual or your dealer could tell you how.
Yeah it is tied to the key fob so if you have two key fob and your wife uses one and you use the other key fob than everything will be the way you want it to be.
omg!!! I didnt know that...that sounds super sweet. Even though I'm the only one with the key and my parents only drive it on special occasions..this is a nice feature!
I read the manual. You get the key fob you want to program and get in the car. You hold the memory number you want and the lock button on the key fob at the same time. You will hear a beep after about 1 second telling you the key fob is programmed to that memory button.
