Staggered Offsets/Tires Advice
I know another thread needing wheel help...Well I trust the knowledge and advice of the members on this forum more than I do local tire shops.
On my 2006 GS300 I currently have 2 bent rims (20x8.5 non staggered on stock suspension) and it's time for a new setup.
Needing to get some new rims and tires ideally by Saturday. I would like to use the new setup on stock suspension for a few months until I get some coilovers soon.
After wearing out the Search button I need some advice on lowering with the following wheel setup:
20x8.5 +37 245/30 or 245/35
20x10 +44 275/25 or 275/30
I don't think those specs would give me any issues on the stock suspension setup (or will it?), but do you think I'll be able to do a nice drop on coilovers later on?
If this set up is ok, how low would I be able to go w/out fender modifications?
Or does anyone have a recommendation for another Rim/Offset+Tire setup that would work with a nice drop on coils without fender mods involved?
Let me know what you think, thanks in advance!
Former Sponsor
In regards to tires, the first set you post is as close to stock as possible, the 2nd set is meatier but still should not give issues.
GS Gallery here
http://www.vossenwheels.com/gallery/.../Lexus_GS.aspx
Here is one for example
Our warranty info
Hope this helps a little bit.
Mike
Thanks for the replies!
With the above mentioned Rim and Tire specs, what would ya'll recommend to be the ideal offset for the front and rear on a 1.5" - 2.0" drop w/out fender modifications?
Or would those +37 and +44 do the trick with a 1.5" - 2.0" drop w/out fender modifications?
I've read alot of good things about Vossens on this forum, what kind of price range are we looking at for the type of setup I mentioned above? $500/wheel? $1000/wheel?
I'm lowered about 2-3 inches (im AWD so I started out a bit higher than RWD) running Vossens 20x9 +38 with 245/30 on the front and 20x10.5 +45 with 285/25 on the rear. I never had much problems until I put a camber kit on the rear bringing my wheels more flush causing it to rub slightly when I hit hard bumps.
The Vossens working out pretty good for you? Any problems with the outer barrel denting/bending?
I like a simple 5 bar design and am partial to chrome (personal preference). The VVS 084's look pretty clean.
Ok I'm riding o. 20x9 30offset in the front and 20x10.5 in the rear 35 offset. I do not rub at all and have rolled my fender. 235/20/30 in the front and 255/30/20 in rear on coils. Riding on strausse forged wheels and I can tell you you will find a better wheel company to do business with out there. Rob thier sales guys make sure you are involved every step of the way. JMO check them out if you want a set of well built wheels.
Oh ok. So it only started rubbing once you corrected the camber with 10.5 +45?
I have the black machined vv-82's, but love the vv-83's too. IMO Vossen wheels are all clean designs that match with the car's class. If you are looking for more of a modern trend design, the concave series would be the way to go. Concave is not for me as I love me a nice set of deep lips!
I would go with the 20x9+32 and 20x10.5 +39 Vossen makes these offsets and put a 245/30-20 (f) 285/25-20 (r) I went with vredestine sessanta tires and absolutely love them they have a rounder sidewall granting more clearance without stretching. You should need very minimal fender mods if any at all with this set up. This is still a conservative set up but leans toward the more aggressive side of the spectrum anything less aggressive will start looking weak. I have had 3 sets of wheels and all different sized spacers from 5-20mm on this car I know my ****
Swtjlsy
Thanks for the input. I'd prefer not to mod fenders if possible. What price range do those Strausse forged run per wheel?
Kcook700,
That's good to know, roads kind of suck where I live so I break rims easily.
Lkapimp216,
Yeah I've seen a lot of your posts on wheel/offsets along with a few other members which is why I know y'all are going to lead me I'm the right direction.
So which that +32 and +39, how much fender mods you think we are looking at here without lowering and with lowering?
Do you have any other offset suggestions that wouldn't require any fender mods with and without lowering?
Mike,
Can you throw me a quote on some vossen 084, chrome is available or silver w/chrome barrel.
Hopefully with the help from the members here on this forum i'll be able to find the best offset and wheel setup which won't require and fender mods lowered and not lowered.
Looking to order rims and tires soon so any input is much appreciated, thanks again.
Kcook700,
Lkapimp216,
Mike,
You may need to trim the inside fender edge slightly but if you use those vredestines you may just clear. My fenders were shaved before I had I thus set up, but I know that it's conservative in comparision to what I'm running now. I have a 12.5mm spacer in the rear and a 20 mm on the front if there is a slight shave needed it will be the rear.
Former Sponsor
Yeah, once I put the camber kit on it started rubbin. These are my second set or rims on my car and I love them. Although the wifey drives the car a lot, I cringe when she gets close to curbs, LOL. No problems with the barrel or lip. You can tell these are quality wheels. If you are worried about the lip, you may want to go with a more conservative tire and not so much of the stretch look to protect the lip more.
Happy 4th everyone!
Lkapimp216,
Oh i see. How low (inches) are you dropped?
Do you bottom out or scrap or anything like that (turns, drive ways, speed bumps, etc...).
No rubbing/scrapping, is that your car one deep or with a full passenger load?
With the 12.5 R and 20 F spacers whats that put the total offset at?
Mike,
Got your PM, good looking out.
Sorry for any poor grammer and/or spelling, i hate posting on iPad/iPhone.
If anyone else has any input or has any personal experience they'd like to contribute it would greatly appreciated. Thanks again for all your help.
Mike,
I am lowered 3+inches and scrape on everything but I don t have to daily drive my car. I can still go over smaller speed bumps there is technique involved when driving this low and I must say I have turned into a beast at it the trickiest thing is not clipping the front fenders while turning and hitting bumps. My rims should stretch my front tires more and help with this. Atleast that is the idea My set up isn t very realistic for everyday driving but you would be surprised how much I push it! My offsets with spacers are 20x9+12 &20x10.5+26.5 my new wheels are going to be 20x9.5+17&20x10.5+26 they should be here by Sept. these specs with significant tire stretching push wheel fitment close to the maximum before you need fender pull and/or camber kits, neither of which I desire to do at this point.
