Stock gs460 dyno!
Old 07-11-11, 04:05 PM
Rider
Rider's Avatar
Default Stock gs460 dyno!
Went ahead and dynoed the car today!! Making the car stick to intended gear was a bit tricky, but managed to dyno the car in 5th gear without it downshifting after throttle is applied. Here we go.
Reason for the dyno is to have a baseline to compare with after installing the invidia exhaust system!
A little teaser
Old 07-11-11, 07:50 PM
MK369
MK369's Avatar
Please post video after you install it!
Old 07-11-11, 08:10 PM
Justin2JZ
Justin2JZ's Avatar
Those numbers seem kind of low.
Old 07-12-11, 02:43 AM
twylie
twylie's Avatar
109 degrees F and the fact that their spec is detuned to 322hp. 20% loss would have them at 257hp, so I'd say given conditions, it was better than I'd have expected.
Old 07-12-11, 04:48 AM
designo
designo's Avatar
Great stuff Mahmood, I'm loving what you're doing! Really excited for you bro!
Not really, here was my dyno sheet, almost the same!
Old 07-12-11, 09:20 AM
Justin2JZ
Justin2JZ's Avatar
Oh, well excuse my ignorance. I thought 460's had 342hp. And 20% of 342 is 274. Correct me please if im wrong.
Old 07-12-11, 12:18 PM
twylie
twylie's Avatar
US Spec GS460 = 342hp, Middle Eastern Spec = 322hp. 20% loss on the 322hp puts them at just under 260 which is in line with both members from the M.E. No one has received a good answer as to why theirs are detuned.
Old 07-12-11, 03:12 PM
Rider
Rider's Avatar
Car is at the exhaust shop! Then will head for tires/rims/springs installment .. will post vidoes soon
Old 07-12-11, 03:35 PM
Justin2JZ
Justin2JZ's Avatar
Oh okay. I understand now
Old 07-12-11, 10:28 PM
designo
designo's Avatar
Mahmood, your A/F ratio looks fine! That's a worry for me cause based on my results, I assumed or cars were running too rich!
If indeed our cars are not, then the Apexi Neo is a waste of time for me and I might as well not risk it!
finny76
GS F (2016-present)
15
07-21-19 01:14 PM
pakeeno
RC F (2015-present)
19
01-19-18 12:30 PM
Ramfis
IS F (2008-2014)
13
05-11-16 09:13 AM
Polkman
IS F (2008-2014)
32
08-09-13 11:40 AM
slowIST
IS F (2008-2014)
05-04-09 03:01 PM
Quick Reply: Stock gs460 dyno!
