Camber and Toe help.
My front wheel camber:
Front left: -1.54 ; Front right - -1.42
Rear Left: -1.54 ; Rear Right - -2.24...
After adjusting toe; Front - 0.03 and Rear - 0.06. thrust angle 0.00...
Does this seem right??
it seems a little off my rear is 3.3 and 3.5 and my front is 2.9 and 3.1 so the numbers are never going to be perfect. Are you lowered on springs or coils cause springs drop the car unevenly where coils can lower the car evenly and this will cause your camber numbers to be more uniform. Megan makes rear camber arms for our car I just ordered a set from Dan @ Assault tech he gave me a great deal.
The Maker
http://figsengineering.com/suspension.htm#arms
This is all you need.
Your settings are only off a little and my arms adjust on the bottom so it will not sacrifice wheel clearance.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
