just changed HID bulb on pass. side and problem
So my pass. light went out and replaced it with an OEM one. after i replaced it, the beam is not the same as it was before. It has a hot spot on that side. Is the ARC on the bulb suppose to be facing down, up, side (towards car or facing the street)? Did I not install it right? Help pls!
Thanks
Thanks
When it's in properly it sits completely flush, if it's not flush you can still force the clip over it but it will not be installed right. Unfortunately it's a pain in the butt to figure out if you have it in there correctly or not, there is very little feedback by feel and difficult to see.
Also yes, it stinks that you have to have your hand in there with a finger on the bulb (in the way, of course) to hold it in the right place until you can get the clip on it with your other hand.
TXES350
ES - 5th Gen (2007-2012)
03-12-11 07:46 PM
