Vossen 083's convinced!
After a week of soul searching, going back and forth! I am now convinced and nothing will change my mind! ( I hope )
Between the CV3's and the VVS083's, I am now convinced the 083's will look better and blend in better on my Mica Red GS. The sucker punch was lkapimp216's post of his 083's on his black beauty!
So the question:
20x9 +32
20x10.5 +39
Can I run 245/35's on the front, and 275/30's on the rears? I am lowered on BCR's and fenders are rolled.
What do you think? I don't slam my cars, they sit with a 1 inch gap which I am happy with!
Can I run 285's at the rears? Should I go for a 30 front/25 rear combo tires?
Your opinions highly appreciated guys!
So the question:
20x9 +32
20x10.5 +39
One more thing concerning the offsets! Just saw this thread again, offsets for 3GS are 38 and 45?
https://www.clublexus.com/forums/clu...gain-pics.html
No run a 245/30-20f and 285/25-20r this will keep you in spec and have less chance of rubbing I was shaved already when I got these wheels cause I had 22s first but Im pretty sure my offsets will only require minimum fender mods on the rear if any. I love my Vossens but will be moving on to another wheel by end of August, still plan on keeping Vossens as a back up wheel
So basically, lkapimp216 is running a +32/+39 offset which is more aggressive than the advertised +38/+45 for the 3GS.
Am I correct? Because looking at his pictures, I love the stance and aggression of his wheels! But those are teeny tires @ 9/225-30/20 10.5/245-30/20.
So what offsets do I need to be able to run 245/30's front and 285/25's rear?
I'm going for silver finish. I hope they are in stock and ready to ship out!
So okay, I am still confused with the offsets!
Although yoondog is running 245/35's front and 275/30's rears, his offsets are +32/+45
Which offsets should I get? I think I'm going for 245/30/20 fronts and 285/25/20 rears.
https://www.clublexus.com/forums/6572204-post14.html
I still wanna drop it maybe another 1/2 to 1 inch. There's a picture posted up there. I will post more up soon. I'm dropped on Tanabe Sustec coilvers and also slightly rubbing on turns and some dips but I'm planning to get my venders rolled and shaved.
if you go for +32/+45 and 245/35 and 275/30, it's overspec, car will run fine but you will likely have rubbing, especially rear. but even front i think you will run into some issues. if you go with 245/30 and 285/25, you will likely be fine, if you still rub in the back, just take off the black plastic trim and you should be good to go
otherwise you will need to play with fenders
