Looks like he wen't with aftermarket rotors, which don't have the hub part painted. Take it off, sand it down, get some engine paint that resist up to 1000 F heat and spray some on it. I did it with my front cross drilled and slotted rotors. They look fresh .
Should I put some type of anti-rust spray/paint on it? What kind of sand paper should I use too? Would any work? Thanks for the input guys!
I used flat black paint, 2 coats, 1 coat of high heat clear coat. For sand paper I used a medium sponge sand paper which can be found in home depot for under $3.
