I-Pod adapter with Levinson System advice please...
Hello, I have a 2006 GS300, with the Mark Levinson stereo, Navigation, XM (not in use). I am looking for an I-pod adapter (hopefully also with a generic "aux" input jack), that I can control through the factory controls, and that has good sound quality. I have read of alot of compalints from people having issues with an Ipod adapter with the Mark Levinson System. Does anyone have any experience with a similar car & the Mark Levinson, with an Ipod adapter they are happy with?
I do not have XM radio hooked up, so I don't mind using that input, but I do not want to lose any other features.
I have also heard there is a way to bypass the car not letting you control the Navigation system while driving, and that will letyou play DVD movies on the Navi screen... Is there a product like that?
Thanks for any help!
vaistech sl2i-up with on 06 gs no problem, i have done a few all works perfect. it has ipod cable directly, no aux input
for override, if you have 06 i believe you can do finger dance to override your nav. look up the sticky diy thread. for dvd override, you can cut wire or get override pnp kit, also in diy thread
I went with an alternative to Vaistech, USA Spec.. Same thing like Vais tech but I have Ipod, Sirius/XM (Custom setup) and Aux.. On my setup, only the Ipod is controlled thru the Factory Head unit, SAT controlled from its own tuner (how i wanted it) and Aux cable for additional sources via 3.5 mm cable.. Works Great and has CD quality. Most Adapters let you control Ipod/SAT thru your factory radio but I don't know of an Adapter that lets you control an AUX thru the Factory Head Unit, the USA Spec has an AUX but its not controllable.. If you want to do Video - I would look into Vaistech..
I have the dice mediabridge BT, product is pretty good, however, the support staff they have answering the phones is clearly terribly trained, 2 out of 3 I have spoken with know less about their product than I do and 1 of them KEPT insisting I should just buy a viastech for video input....WTF???
that guy should be fired, he clearly has no desire to help with the brand he works for.
I don't discount that fact, but what kind of employee tells a customer that already owns their product to go to a competitor.....when that customer NEVER mentioned he wanted video at all.
Rosson3ri
02-02-16 11:49 PM
jre002
10-29-12 06:12 PM
