My concept one rims is here..
ok i just got two of the four rims today.. not happy at all... anyways! it has to do for now.... it 20x10 the et 33 so it the back im guessing... the fronts rims on the way tomorrow. if the back offset 33 they told me 35 front 45 back f****R! would this still if my gs? i know i need 35+ offset in the front.. if the back it 33 damit im sacred the front is lower then 30.. ![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
You have to be more specific on wheel specs, a 20x10 +33 will work with a shaved fender in the rear. A 20x10 can be as aggressive as +20, or +21 before a fender pull, or adjustable camber arms are needed. I have a 20x10.5 +26, but have the inside of my rear fender shaved, and grinded flat so there is no edge, and smooth. I can tuck rim just barely with a 245/30 stretched. The fronts im 20x9 +12 so a 10 in the front can be as aggressive as +24, or around there. You should be fine just may need to stretch tires get a air saw, and grinder, followed up with some touch up paint, and rubberized undercoating spray relax bro!
You have to be more specific on wheel specs, a 20x10 +33 will work with a shaved fender in the rear. A 20x10 can be as aggressive as +20, or +21 before a fender pull, or adjustable camber arms are needed. I have a 20x10.5 +26, but have the inside of my rear fender shaved, and grinded flat so there is no edge, and smooth. I can tuck rim just barely with a 245/30 stretched. The fronts im 20x9 +12 so a 10 in the front can be as aggressive as +24, or around there. You should be fine just may need to stretch tires get a air saw, and grinder, followed up with some touch up paint, and rubberized undercoating spray relax bro!![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
you will definitely clear the fender you ll actually be conservative you may wanna throw a spacer on it. depending on how aggressive you wanna go I would stretch a tire if you wanna be flush, if you want some meat on the tire you should be able to properly stagger with a 245/30 and 285/25 this will keep your speedo perfect and front a rear tires will be the exact same overall diameter. Im stretching a 225/30 on a 9 soon to be 9.5 and a 245/30 on a 10.5 and I drive the hell outta my car, like I stole it!!!! Too much testosterone bro!!! Goodluck!!
I'll go for saying mine are conservative but not these. You can't call sizes requiring any type of stretching, rolling, cutting, shaving, etc. conservative. You just can't.
If you are saying he won't need to do anything to prevent rubbing, then I can see it. I don't agree he won't. I believe he will have to do something.
