CD player has no sound
Old 09-20-11, 11:47 PM
Kevins408
Kevins408's Avatar
Default CD player has no sound
I have a 2007 GS 350 ML. Recently the CD player has no sound. It plays the cd and you can change tracks, yet no sound comes out. While the cd is playing, you don't have the ability to change the volume. Sound does come out on the radio and XM. When I play a MP3 CD sound does come out and i can change the volume. Funny thing is, when i'm playing a cd and hit a small pothole or road marker sound comes back on. Don't know if it's a loose wire or something. Can someone please help?
Old 09-21-11, 01:56 AM
XxGoKoUxX
XxGoKoUxX's Avatar
is your car still under warranty? go take it back to get it fixed
Old 09-21-11, 05:38 AM
bigblack06
bigblack06's Avatar
Sounds like a wire might have slipped out, you might need to get to the back of the unit or bring it in to service. There is a DIY on the forum on vaistech that should help you on how to take it out to get to the unplugged wire.
Old 09-21-11, 08:37 AM
rominl
exclusive matchup
rominl's Avatar
sounds like a loose wiring
Old 09-22-11, 06:29 AM
SMGS300
SMGS300's Avatar
Sounds like another blowin ML amp
Old 09-22-11, 07:37 AM
Kevins408
Kevins408's Avatar
Car is out of warranty....going to open the head unit. I talked to my service adviser yesterday and he never heard of this happening before (typical).
Old 09-22-11, 10:07 AM
Ap1_Alan
Ap1_Alan's Avatar
if the amp was blown there wouldn't be any sound. He is getting sound, just not from the CD player
Old 09-23-11, 08:35 AM
Ashdaddy
Ashdaddy's Avatar
Sounds like a loose wire.
Old 01-04-14, 03:51 AM
rjp883
rjp883's Avatar
What was the outcome of this - did you manage to sort out the problem? Where was the fault in the end? I have exactly the same fault and symptoms with my LS600hL (2009 model). Amazing car notwithstanding this fault! Thanks
Old 04-17-14, 10:24 PM
Rickis350
Rickis350's Avatar
I have a 2007 IS350 with the exact same problem. How did this problem get fixed?
Old 04-19-14, 07:59 AM
100310's Avatar
amp blown, I got the same problem.
Old 04-19-14, 07:41 PM
Rickis350
Rickis350's Avatar
How did you determine it was a blown amp? That does not make any sense unless the CD play uses a different amp than everything else? I would assume the radio and the CD player uses the same amp? Did putting a new amp in fix the issue for you or did the dealer just say it was a bad amp?
Old 04-20-14, 09:49 AM
lexjxn
lexjxn's Avatar
I have the same car and issue as the OP.. radio has sound and mp3 cd has sound but not a store bought cd. I'm not sure what actually happens, but going by how I fixed it it must be a loose wire.
what I did was I finally got mad and I gave the front and side of the console a few hits and it started working lol
The side, as in the leather part that runs from the foot well all the way to center console. I used the side of my fist to hit into the passenger side of the console and it started playing. Not saying that was a good idea, but the sound has gone out again (probably from a bump in the road) and I have done the same process to fix it again.
I'm probably going to take the head out one day to check connections but I just haven't done it.
I have read several threads on this issue but none of the "amp" issues made sense as my radio/cd player would work. One suggestion that playing an mp3 cd (i.e. with 100 tracks) will cause the computer to get confused and not play other types of media made a little sense, but that turned out not to be MY issue.
Old 04-21-14, 07:24 AM
100310's Avatar
Sorry,my bad, my situation is no sound coming out even Bluetooth..
Old 04-21-14, 12:57 PM
Rickis350
Rickis350's Avatar
Fixed mine this morning with a bang on the trany tunnel right next to the nav on passanger side. This issue is due to a bad connection somewhere.
Quick Reply: CD player has no sound
