Last edit by: Tony Greene
Browse all: Wheels & Tires How-Tos
- Why are My Tires Wearing Unevenly?
Guide to diagnose trouble and recommended solutions
Uneven tire wear problem
i guess what i meant was that there is no adjustment for camber only. you can adjust rear toe, but this doesnt entirely fix the uneven wear issue. the factory setting for camber on this vehicle was set up for optimal handling not tire wear. when i looked at my GS on the alignment rack yesterday, i couldnt help but think, would it really have been that hard or costly for them to put another set of alignment bolts in the rear? by the way, if you usually carry a lot of weight in the trunk you should align the vehicle with this weight in the trunk to prevent inaccurrate adjustments.
you just can't have the best of both worlds i guess
i would like to add that there is no rear camber adjustment on the GS's. so an alignment will do nothing to fix this issue. i have seen the same issue with an Audi TT in the past, and we were able to find an ajustable aftermarket replacement for the lower rear control arms. you may want to see if there are any adjustable lower arms for the GS, however, i am not aware of any.
![Hello](https://www.clublexus.com/forums/images/smilies/hello.gif)
We need to make sure we are providing accurate information for those that are less educated when it comes to cars. Sites like CL are the only source of information for some.
I was just at the dealership today and they showed that my front left tire is getting worn bad on the inside of the front driver side. Is this what is causing my car to pull to the right so badly? (Have had 3 alignments in the year all showing within acceptable degree range).
I had my car lowered about a year ago using F-Sport springs, nothing else. He said that the dealer SHOULD have told me to get a Camber Kit installed to correct this problem. He had recommended me calling the dealer that installed these and b1tching at the service manager for them not telling me.
Looks like I need to replace that tire (as well as the other side even though not nearly as affected). Should I get both front tires replaced, or just the one that is affected? Also, is this most likely the culprit of this problem, and if so how much should I spend TOPS to fix it?
![](http://i109.photobucket.com/albums/n56/Deez_Nutz4u/photo.jpg)
![](http://i109.photobucket.com/albums/n56/Deez_Nutz4u/tire2.jpg)
So this is something I can fix with just the camber/toe settings? Or do I need a install a camber kit to fix this (noob on this topic). Aside from the pulling, I need to fix this because it will keep eating my tires up -- I assume I need to replace this tire (do I have to; or should I replace the other front tire as well even tho it looks ok?).
for your tires, they seem to be directional. why not flip the tires left and right for the front so you have another "new" edge to wear out? i did that to my toyo all the time, got 30k (15k on each edge).
for the alignment, it really depends on your lowering and such. i don't think you can take away uneven inside wear completely, after all you want some camber to help on handling. but i think you can get a bit more even wear. you can get camber kits, but in the end if you want to align it back to factory spec, you will have camber and you will have more inside wear. that's just part of having a performance vehicle.
If I understand correctly, installing a Camber Kit will help even the wear out but never fix it completely (always leaving more inside wear than normal). I'm assuming best move is just rotating the tires, might even help offset the pull as well...?
everyone has different priorities and i can only tell you what i think (and did).
i don't really care about camber kits. they are money, time and trouble on install (and uninstall when you sell the car), one more possible to get alignment out of spec (moving parts) though might be unlikely, and most importantly, unless you get to 0 camber which results in silly handling, you want some negative camber which means somewhat uneven wear anyway (matter of severeness).
you can search pictures of my car and see how low my car was. and i was literally riding just on the edge of the tire. it's not a good picture but you can see the wear here, just the edge. the center part of it is basically new (please don't mind the bubble...)
![](https://www.clublexus.com/forums/members/rominl-albums-gs350-part-out-picture19793-img-1569-resize.jpg)
so my criteria? i wanted some good performance tires, has to be directional so i can flip the tires left and right, and reasonable tread wear. i ended up choosing the toyo t1r. of course, i did alignment and put a little more toe in to compensate the inside wear
as mentioned, i got 15k miles on each edge of the tire, so 30k out of a set of tires. really i think that's not bad at all, some factory tires don't even get as many miles.
at least in my situation, i think this plays out better / cheaper / easier than doing any control arms and camber.
but again, that's me. i respect other people for thinking different
So with my FALKEN FK452 you said I can switch sides/rotate them correct? I would think directional would only be able to be on one side...?
all you need to make sure is that the tires are directional. that means they can only spin one way. for those tires, what you do is you take the left side tire and put it on the right side, and right to left. that's what i meant by "flip".
for asymmetric tires you are out of luck because they are either outside or inside, so flipping won't help anything at all.
i don't know of any tires that you can only put them on one side.
The wear being on the inside drivers side would now be showing on the outside passenger side and visible from the street. (Would basically look like that tire was bald from the avg. person).
