help car wont start!!!!! i just changed the battery
Old 10-15-11, 09:19 AM
johnnunez2
johnnunez2's Avatar
Default help car wont start!!!!! i just changed the battery
i got up today to find out my cars battery is dead."clicking" i chnge it and now my brakes wont depress and the car wont turn on. if i press the button it will turn the dash on and all but the car wont start. i dont know what happened.
Old 10-15-11, 09:43 AM
neurocity
Neu`roc´i`ty
neurocity's Avatar
Don't take this wrong, but I have to ask...
1. Battery is connected and secured properly?
2. Battery is charged?
3. When doing the swap, none of the contacts touched the car while the other was still connected?
Get some jumper cables. let the jumper car run for a while to get a fairly decent charge on your battery. See if anything changes.
Old 10-15-11, 10:00 PM
Mikeyy
Mikeyy's Avatar
describe it more
does the car crank or does it just click when u press the button?
Old 10-15-11, 10:35 PM
GS350Lexus
GS350Lexus's Avatar
Try to check the fuses underneath the steering wheel.
Old 10-16-11, 12:19 PM
BurgBoxstr
BurgBoxstr's Avatar
wouldn't be first time a "new" battery is bad off the shelf...
Good to always have store test and show you report before just taking it out of store assuming all is good.
Get battery tested first then look to electrical system... unless of course you know you left car on after swapping. In which case, you just need to fix the short between steering wheel and seat
Good luck
Old 10-17-11, 03:47 PM
johnnunez2
johnnunez2's Avatar
Good luck
lol. good one.
i actually figured it out. idk why my brake was pressed and stayed stiff, but i pressed it even harder and pushed the button and it started. like i said though, still confused as to why the cars brake pedal stayed down and stiff
Old 10-17-11, 04:46 PM
BurgBoxstr
BurgBoxstr's Avatar
Originally Posted by johnnunez2
lol. good one.
Congrats - glad you got it started!
When was the last time the brake system was flushed or even bled? Hopefully not, but you may be having problems w/ the master cylinder or at a min w/ water in the lines. Since you sound like an above avg DIYer, I'd suggest [at least] bleeding the brakes as a starting point...
Good luck
Old 10-26-11, 04:25 AM
johnnunez2
johnnunez2's Avatar
Good luck
thank. the brake only got stiff and stuck after the battery was taken off. i just changed my brakes and all my brake fluid about lest than 3k miles ago. idk what the hell that was! . guess, ill never know. oh well, aslong as its fixed. thanks again.
Bimsimack
09-13-18 01:15 PM
akafixture
03-12-17 02:23 PM
R Z
12-24-14 11:51 AM
AlexusAnja
09-25-11 05:47 AM
tmf2004
01-08-06 09:36 PM
Quick Reply: help car wont start!!!!! i just changed the battery
