Lowest Offset Without Spacer
The stock wheels on my GS450h have an offset of 45. If I were looking for new wheels and wanted to stay with the stock size wheel of 18X8, what is the lowest offset I could get away with and not have to use hubcentric spacer? I am also looking to stick with with the standard size tire 245/40-18. Thx!
One thing you could do, is get a ruler and rule out how many MM it takes to reach your "limit" as to where your wheel can stick out.... take that and I believe subtract from your 45mm offset, that's how you know what offset you want ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Chime in anyone who believes i'm wrong here.
So based on what rominl says, a wheel with an offset of 40mm will stick out 5mm more than the stock wheel which has the 45mm offset. Does that also mean the wheel should clear the caliper and everything else easily? Again assuming we are staying with the stock 18X8, 245/40-18 setup.
tarponman
09-30-09 07:03 AM
