Should I shave my rear fender
Old 10-27-11, 03:16 PM
JH48
JH48's Avatar
Lightbulb Should I shave my rear fender
Im on stock suspension,but the rear fender are rubbing when I got 1 person in the back and make the sharp turn.Should I shave my fender now or wait until I lower my car. Does it still rub after shaving it? Im on front 19x8.5 +22 tires 235x235x19 rear 19x10 +26 tires 245x40x19
Attached Thumbnails Should I shave my rear fender-sam_1021.jpg   Should I shave my rear fender-sam_1022.jpg   Should I shave my rear fender-sam_1026.jpg   Should I shave my rear fender-sam_1028.jpg   Should I shave my rear fender-sam_1020.jpg
Old 10-27-11, 04:16 PM
TWong350
TWong350's Avatar
Yes, you should shave. May as well do it now and get it over with before you lower it.
Old 10-27-11, 04:32 PM
JH48
JH48's Avatar
but does it still rub if I got 3 or 2 peoples in the back with low and without low?
Old 10-27-11, 04:43 PM
Mesca
Mesca's Avatar
You might as well shave it now because you are DEFINITELY going to have to do it if you wanted to drop it.
Old 10-27-11, 04:47 PM
JH48
JH48's Avatar
ok, but does it still rub if i got soome people in the back and do sharp turn?
Old 10-28-11, 03:49 PM
Mike1970
Mike1970's Avatar
i vote for shave. i had 19x10 +32 in the rear and i had to shave mine
Old 10-28-11, 05:30 PM
msgs350
msgs350's Avatar
U still might rub. 10" wide and +26 is pretty aggressive for a 3GS. The tires seem kinda "tall" also in the rear.
Old 10-28-11, 07:26 PM
JH48
JH48's Avatar
I got my rear fender shaved last night, but early im on the freeway when there r road up and down like wave it rub, and one person in the back
Old 10-28-11, 11:11 PM
Mesca
Mesca's Avatar
Yeah..you rub because those are very aggressive offsets in the rear..if you want you might need to try a pull on those fenders as well.
Old 10-28-11, 11:28 PM
JH48
JH48's Avatar
I heard pull the fender have to repaint the fender is that right. I havent drop my car yet with 1 person already rub, so when I drop that mean cant take anyone in the back
Old 10-29-11, 12:53 AM
Mesca
Mesca's Avatar
You can get skinnier tires as well to relieve the rubbing.
Old 10-29-11, 04:57 AM
pqn628
pqn628's Avatar
I shaved my rear fenders and no more rubbing. I'm running 20x10 +45 with 35 series tires.
Old 10-29-11, 08:25 AM
JH48
JH48's Avatar
Alrite I will try that after my tires ball thank you guys
Old 10-30-11, 06:13 PM
lkapimp216
lkapimp216's Avatar
first the offset is fine, thay are aggressive but no pull is necessary however you will definiely need to shave the fender almost flat inside here is what mine looks like and I am about 6mm more aggressive than you and second thing is that your tires are overspec you should have a 245/35-19 on the rear and 225/35-19 on the front those are the specs im running on the 19s I have no rubbing at all fron t or rear and those are (F) 225/35-19x9.5 + 17 and(R) 245/35-19x10.5 +25
Attached Thumbnails Should I shave my rear fender-6142311718_9722fba2b1_b.jpg   Should I shave my rear fender-images.jpg   Should I shave my rear fender-6152563609_380788362e_b.jpg
Old 10-30-11, 07:11 PM
JH48
JH48's Avatar
Cool and nice car. I will do that for the next tires.
I wondering how low are you lowing ur car?
Quick Reply: Should I shave my rear fender
