low pressure lights when its cold
Old 01-05-12, 09:13 AM
rominl
exclusive matchup
rominl's Avatar
Originally Posted by 06ausiecar
Don't forget about you spare also. If that is low it will trigger it also. I know the early tc's had a little issue with them. Toyota recommended to let the air out of the tires wait a bit then refill. Seemed to work on a friends 06 Tc. Her light stayed on even with correct pressure. I know that's not how you reset but it worked.
i think we covered this before already, spare has no tpms as far as i remember
Old 01-05-12, 09:29 AM
worker
worker's Avatar
Originally Posted by steviej
Best thing to do: when it is cold outside, bring your tires up to your desired psi and then re-initialize the system. You should be good for the rest of the winter. If the light comes on and stays on again after that, check the tires for leaks and physical damges.
don't need to re-initialize. Once the psi is around 35 the light will turn off on it's own. And yes I agree should go and pump it up to the recommended psi when the light start to turn on/off.
Agree. I didn't see any tpms.
Old 01-05-12, 09:34 AM
07LEXPL
07LEXPL's Avatar
common sense, once it gets cold, air pressure gets lower. lol, weird topic. guess its the first car for some that has tpms. you must have been driving on low pressure in your old cars.
Once the frost hits check pressure, same thing with spring time.
waynedog
11-20-13 08:18 PM
puckhead85
10-09-13 03:49 PM
astrotoy
11-07-09 11:28 AM
is250al
11-28-07 03:52 PM
boolabob
01-20-07 09:14 AM
Quick Reply: low pressure lights when its cold
